My current speaker system consists of Peerless XLS 12” subwoofers in IB boxes, with Seas metal midrange (L17RNX/P) and Seas metal tweeter (27TBFCG) in small closed “satellites”. Electronic crossover at 100 Hz and 2 kHz, power amplifiers are Elliott P101 and two old NAD 214 units.
My next loudspeaker project will be dipoles – separate subwoofers, mid/tweeter “panels”, electronic crossovers and Elliott P101 amplifiers. Woofers will probably be ripoles with dual 12” Peerless SLS units in each. EQ-ing and filtering as required. I am unsure about mid/tweeter panels, though, and consider two alternatives: • “Phoenix-style” MTM dual 8” midrange (Seas metal) plus tweeter (27TBFCG, probably with a waveguide) , crossover between 1200-1400 Hz • or a “WMT”-configuration with a 10-inch Seas metal L26 unit handling 100-300 Hz, a 6 inch L15 unit 300-2000 Hz - plus tweeter. The former alternative is perhaps the least complicated – but I am concerned about the compromise between (on one side) the power handling of the tweeter and (on the other side) the cone breakup/distortion and the increasing directivity of the metal-cone midrange units. The latter alternative offers the possibility of a higher tweeter crossover frequency which obliterates most of the mentioned problems - but with the added complexity of extra crossovers and units, less symmetrical vertical-plane dispersion and the need for somewhat higher cone excursion in the 100 Hz-area. (Even though it is desirable, I have not room for bigger mid/tweeter panels with more units. I also think that MTM mid/tweeter panels with 6 ½” units (in place of the 8” units) will suffer too much in power handling and is no desirable alternative). Any thoughts/advise on those alternatives? Regards, EspenE |
#2 | |
Crossing at 1200-1400 Hz as suggested, there is almost no increased directivity of the midrange unit itself (looking at the SEAS SPL graph). You certainly should be more concerned about the figure 8 dispersion of the dipole, which gives another kind of directivity and might be in conflict with the tweeter dispersion. But Linkwitz et al haven´t found an issue there - so why should you care.
www.dipolplus.de |
#3 |
Hi Espen
I'm using dual Peerlees 12" ripoles and bastanis Prometheus (www.bastanis.de) and must say it's one of the best speaker I'v ever heard. It's very sensitive (100dB/W) and can take a lot of power. I'm happy with 2watt's but it can take 200... I used Quad ESL 63 before, and I was happy with them. But I do not miss them after the these broke in. Here is a pic of it: http://home.no/tricoloreis/diff5.jpg Best regards bjørn |
#4 |
Your mailadress does not work. Send me a new address and I'll respond :-)
bjørn |
#5 |
Bastanis use modified Eminence widerangers. Ciare have a nice 100dB wideranger that doesn`t have that nasty peak as the unmodified Eminences before they say goodbye. I don`t know whether they reach the quality of the (much more expensive) Bastanis, but I read in a German forum that people are very pleased with it.
http://www.ciare.com/pdf/catalogo/PM250.pdf |
| Dipoles ? | LennyK | Multi-Way | 111 | 21st September 2006 03:12 PM |
| Vas, cms, etc... for Dipoles | Raka | Multi-Way | 21 | 19th February 2006 05:43 AM |
| 3-way or 4-way dipoles? | mazeroth | Multi-Way | 0 | 25th January 2006 06:37 AM |
| SPL max and dipoles XLS | Raka | Multi-Way | 11 | 21st July 2004 08:34 PM |
| 'T' baffle dipoles | sfdoddsy | Multi-Way | 2 | 15th January 2003 10:46 AM |
| Page generated in 0.08142 seconds (76.97% PHP - 23.03% MySQL) with 10 queries |
