Hi!
I just received the new Monacor speaker-building brochure and they are apparently very fond of "horn-resonators" this year. It seems to be a mix of bass-reflex and horn, but I dont recall having seen this solution before. If you guys are interested I could probably make some drawings or scan the brochure. The question: What is a horn resonator? Can "normal" peolpe "make math" on it, or is black-woodoo-magic? any links? TroelsM |
#2 |
Some would call it a basreflex with a large port, some rather call it a horn with a big rearchamber and short path length. You can simulate as both and get similair results, none of which will be totally correct or wrong. It's starting to live on most forums now. Mvg Johan |
#3 |
Hi!
See the AES paper linked. http://ncomprod.nokia.com/library/fi...olded_Horn.pdf Maybe it'll give some clues for what is a Horn resonator. @+ Maiky |
#4 |
Forgot one thing: Whats the benefit? Is it as efficient as a horn or more like a bassrefleks-box?
TroelsM |
#5 |
Someone should tell them that the Turbosound TSW-118 is actually a bandpass horn instead of a real bass horn like the EAW LA400.
#6 |
Hi!
I've check the Tourbosound data sheet. It is claimed that we deal with a horn loaded sub! @+ Maiky |
| Tozawa-Resonator : helps absorb 300Hz and below | andy2 | Multi-Way | 5 | 15th August 2011 07:13 PM |
| Resonator guitars | PhaseLockLoopy | Instruments and Amps | 3 | 30th May 2008 04:28 PM |
| Cabinet brace act as helmholtz resonator? | RyanW | Multi-Way | 17 | 2nd October 2007 11:08 PM |
| isobaric resonator? | tade | Subwoofers | 6 | 17th August 2005 07:24 AM |
| Ceramic resonator pinout | trwh | Digital Source | 2 | 21st July 2002 12:35 PM |
| Page generated in 0.09314 seconds (73.27% PHP - 26.73% MySQL) with 10 queries |
