Old 28th September 2005, 05:33 PM   #1
Unhappy Yamaha NS-1000X tweeters blown...whats the problem?
Hi guys,
Imported these fine NS-1000X speakers and the tweeters on both seem to have gone.
What could have caused this? The speakers were both packed very well.
All other drive units function (mid and woofer).
How could i test the tweeters with a multimeter?
Anyone know where i can get spares?
Richard
Old 28th September 2005, 06:13 PM   #2
Default Tweeter
Ohm reading directly across the tweeter should give you several ohms of resistance. A reading of near zero or open indicates problems.
How can a tweeter be damaged, amplifier clipping, overdriving to the point of thermal failure, corrosion, physical abuse..... etc.
Old 28th September 2005, 08:24 PM   #3
Unhappy problems with what?
Does the resistance indicate problems with tweeter or crossover?
Thanks!
Richard
Old 28th September 2005, 09:09 PM   #4
Speakerholic
Cal Weldon's Avatar
If it is a 4 ohm driver, it should read around 3 ohm resistance
8ohm driver = approx 6.5 ohms resistance plus or minus
That's what they should read if they are OK.
If it's zero = dead tweeter
If it's almost infinite, maybe blown tweeter, maybe broken lead
Tell us what you are hearing that makes them sound blown. Do they make sound at all?
Cal
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 28th September 2005, 09:16 PM   #5
Speakerholic
Cal Weldon's Avatar
To check the XO hook up a tweeter you know is good.
Also, try bypassing the L-pads to see if that might be it.
Old 28th September 2005, 09:38 PM   #6
Richard,
Yamaha UK can supply all parts for these fine speakers new, just make sure your sat down when they tell you the price! (Mids are around £350 each )
Paul.
Old 1st October 2005, 10:44 AM   #7
Unhappy measured value
hi guys,
Yeah i measured the resistance and found 3.5ohms across one of them. I think they're a six ohm speaker.
Far out but could it be that i'm using a very cheap sherwood amp? rated at 8ohms?
Could it be the crossover? I ordered new tweeters from yamaha though to find out...in japan they're much cheaper.
I'll try hooking up a known tweeter to see what happens...let the diagnosis begin!
Richard
Old 1st October 2005, 10:46 AM   #8
Unhappy no sound
yeah i'm getting sound from the midrange and woofer but not the tweeter....any advice?
Richard
Old 1st October 2005, 12:09 PM   #9
jez is offline jez  United Kingdom
Are there any tweeter fuses? could be on crossover.
You say that one measures 3.5 ohm, that's not incorrect if it's a 4 ohm tweeter (evan if the whole speaker says 8 or 6 ohms on the back, it may use 4ohm tweeters), what does the other measure? if they are not the same (within a few percent) you have a problem!
Looks like the crossover could have a problem if still no sound with good tweeter, is this the case for both speakers?
Crossovers often have resistive pads or simple in-line resistor to match HF level to mid, could one of those resistors blown. Good luck.
jez
Old 1st October 2005, 05:48 PM   #10
Unhappy measured values
jez
Jez...i measured the resistance across both tweeters and it read the same...3.5ohms. So does that mean its something else or than a faulty tweeter? Or could it still be the tweeters?
Or could it be my little sherwood standin amp just can't power them if they're 4ohms? I do have an Accuphase E307 but its yet to be rewired!
Only problem now is getting to measure the crossover or check it out...the cabinets are sealed and the crossover is right at the back
Any further ideas?
Richard
Is it possible to fix the BLOWN tweeters? Tony.ca Multi-Way 12 23rd February 2010 04:25 PM
Yamaha M-45 Blown Output Transistors gni Solid State 35 29th July 2008 09:47 PM
help blown yamaha amp namcir Solid State 18 12th December 2005 03:37 PM
Yamaha P-2200 blown-up xyonyx Solid State 5 13th November 2004 07:54 AM
Blown Tweeters Ajaz Multi-Way 2 18th February 2004 12:04 AM
Page generated in 0.60710 seconds (44.61% PHP - 55.39% MySQL) with 10 queries
