Old 28th September 2005, 01:52 PM   #1
SSassen is offline SSassen  Netherlands
SSassen's Avatar
Default The Silverado, a small d'Appolito loudspeaker
I've just posted the full story behind the construction of the Silverado on my website, at the below url.
http://www.hardwareanalysis.com/content/article/1815/
Best regards,
Sander Sassen
Old 28th September 2005, 02:29 PM   #2
ShinOBIWAN's Avatar
Excellent work! And it features my fav low cost HF driver
I've been looking for something to build for my cousin and I think this could just be the ticket. Cheap and it looks like it performs well.
One question:
I know you recessed the tweet and surface mounted the mid/bass drivers but have you noticed any untoward effects by doing so? I realise of course that this was in your goals of time alignment.
From the frequency plots I can't see anything that would point to such a thing. Would be interested to hear your thought on the effects if any - afterall it would probably be a different matter if we were talking about diffraction on the tweeter.
Once again excellent write up and thanks for sharing what looks like a very promising design for what is essentially little money.
Old 28th September 2005, 02:47 PM   #3
SSassen's Avatar
Thanks ShinOBIWAN,
What can I say, I aim to please? And I can't stand sloppy workmanship so I try to live up to my own standards. As for the tweeter I haven't seen or heard anything during the measurements or when listening to the loudspeakers, the small baffle did worry me a bit, but it turned out not to be a problem at all. Off axis measurements are only slightly off from on-axis.
Sander Sassen
Old 28th September 2005, 03:48 PM   #4
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Big name for a small loudspeaker, Chevy will sue you.
Craftmanship quality article, Sander.
Old 4th October 2006, 05:56 PM   #5
Russ White's Avatar
Send a message via Yahoo to Russ White
Nice looking speaker project!
What is the impedance of the speaker? 4ohm?
Less pulp more juice Twisted Pear Audio.
Old 4th October 2006, 09:18 PM   #6
SSassen's Avatar
Hi Russ,
Nominal 6-ohms, it never touches on 4-ohm really.
Best regards,
Sander Sassen
Acception without proper examination equals religion
Condemnation without proper examination equals prejudice
Old 11th March 2012, 07:08 PM   #7
ficus is offline ficus  Germany
I know I am reviving a rather dated thread, but I saw your design, and find it extremely interesting. However, I was wondering if you have some thought on whether it is possible to build the Silverado as a sealed speaker, if I were to increase its height into a floor-standing speaker, thereby increasing the volume of the case?
Old 12th March 2012, 01:45 PM   #8
volume of the case?
I found the comment in the write up that a sealed version would need to
be twice as big hard to fathom. Modelling the driver all sealed versions
have very restricted bass, and a 20L sealed box for 2 doesn't work.
Per driver :
10L sealed is - 6dB at 90Hz and -9dB at 60Hz, Qbox = 0.36.
5L sealed is - 6dB at 87Hz and -9dB at 60Hz, Qbox = 0.41.
2.5L sealed is - 6dB at 87Hz and -10dB at 60Hz, Qbox = 0.5.
1.5L sealed is - 6dB at 87Hz and -11dB at 60Hz, Qbox = 0.6.
1L sealed is - 6dB at 93Hz and -12dB at 60Hz, Qbox = 0.7.
They need to be vented to produce any sembance of bass.
5L per driver needs to be tuned between 40Hz and 50Hz.
rgds, sreten.
http://www.humblehomemadehifi.com/do...k-III_copy.pdf
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 12th March 2012, 03:38 PM   #9
A nice looking speaker. Even it is no "real" D'Appolito as the xo-frequency is to high (or the distance of the low/midrange drivers is too wide).
But it seems to work well looking at the measurements.
One way to do a real D'Appolito would be using a fullrange driver as the tweeter with a lower xo-frequency (as we did in our "Sundan").
The Objectives of a Loudspeaker in a Small Room SY Multi-Way 350 12th August 2011 07:43 AM
David: Small vented loudspeaker with bass boost Dominique Multi-Way 4 21st May 2008 03:17 AM
00 Silverado Build xtremekustomz Car Audio 7 2nd January 2007 08:54 AM
Best Small(ish) DIY Loudspeaker System? RussB Multi-Way 3 12th October 2006 09:30 AM
XM input on 2004 Silverado Bose system yak Car Audio 0 16th March 2004 06:31 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
