Old 26th September 2005, 11:56 AM   #1
TroelsM is offline TroelsM  Denmark
TroelsM's Avatar
Default Impedance and SPL..
Hi.
If a 8ohm speaker has an sens. of 93 dB (1W/1m) and a 4 ohm speaker has a sens. of 93 dB (1W/1m) will they make the same SPL if they are connected in parrallel to the same amp?
As I recall it the def of loudspeaker-sens. was something like the measured dB's with 1V across the terminals? - And that canīt lead to the same sensitivity as the W/m def.
Hope this makes any sense to you.
TroelsM
Old 26th September 2005, 12:06 PM   #2
Did it Himself
richie00boy's Avatar
No they won't make the same SPL because the 4 ohm speaker will be drawing twice the current hence 4x the power, so 6dB louder.
What might trip things up is that a lot of manufacturers of 4 ohm speakers inflate their sensitivity levels by using the same 2.83V (which is 1 watt into 8 ohm) to drive their speaker. In that case then they should put out the same SPL.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 26th September 2005, 12:18 PM   #3
TroelsM's Avatar
Hi richie00boy.
I must admit that I dont get your point.
If a 4ohm speaker draws twice the current according to ohm's law then the power will be 2* not 4*!
Any Idea how Monacor does the sens-meas.?
TroelsM
Old 26th September 2005, 12:37 PM   #4
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Originally posted by TroelsM
Hi richie00boy.
TroelsM
Taken the amp volume is the same, thus for P=I*V, V is the same, with a doubled I you get twice the power.
Hear the real thing!
Old 26th September 2005, 12:43 PM   #5
soongsc's Avatar
Default Re: Impedance and SPL..
Hi.
TroelsM
(1W/1m) is precisely what it means. Not the 1V as you think it is. For 8 ohm load, something like 2.83V is used, for 4 Ohm, something like 2V is used.
Old 26th September 2005, 12:52 PM   #6
Did it Himself
You're right, double the power. It's been a long weekend and too many I^2 x R calculations lately
What impedance? jaya000 Multi-Way 11 21st November 2008 07:04 AM
Impedance rate VS impedance stability TomatoBangBang Tubes / Valves 6 4th September 2008 10:46 PM
Hi Vi SD1.1 impedance guitarded Multi-Way 0 3rd February 2008 08:35 AM
Need help understanding transformer impedance ratios and impedance matching percy Tubes / Valves 5 28th February 2005 08:35 PM
2.5 way impedance Vivek Multi-Way 5 15th June 2004 05:51 PM
Page generated in 0.10385 seconds (77.54% PHP - 22.46% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
