Old 26th September 2005, 03:13 AM   #1
Default cabinet design: best frequency range to block
I have happened upon a method I think will work for isolating a cabinet from resonance utilizing constrained layer damping and some other materials. The problem is its more like a band-pass filter for a particular freq range, it cannot block all. It can only block frequency RANGE from passing from the inside of the speaker, and resonating from the outside of the box. The narowwer the range of frequencies, the better I can block them by altering the natural resonant frequency of the box. So I pose a question: what is the narrowest range of frequencies that if blocked, would improve a loudspeakers performance. I am looking for answers between 20-22,000, not trolls. Something like 300-3000 is my first guess, the most sensitive part of hearing, supposedly. Reasoning for your answer would be appreciated as well.
Old 26th September 2005, 03:26 AM   #2
mike.e is offline mike.e  New Zealand
mike.e's Avatar
Send a message via ICQ to mike.e Send a message via MSN to mike.e
Having no box solves the problem.
Id consider anywhere between 500hz-2khz.Your changing the 'voice' of the box,and want to reduce the most audible part,as you know.
See the measurements of loudspeaker vs enclosure output from HARWOOD etc in the 60s.
ply + similar thickness bitumen helps out alot. B&W honeycomb fancy stuff looks interesting too.
Cant help much sorry.
Old 26th September 2005, 03:34 AM   #3
The higher frequencies are easily absorbed by stuffing.
Frequency range of the human voice & full range center channel speakers jwmbro Multi-Way 31 20th January 2008 03:07 PM
AAC block for speaker cabinet exipnos Multi-Way 1 18th January 2007 08:33 PM
SNR/Dynamic range worsens in low frequency range. percy Digital Source 3 1st June 2006 12:41 PM
Frequency CUT and a HOLE in frequency range... -_nando-_ Everything Else 0 28th December 2005 08:17 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
