w00t w00t...
For those following my project, I decided to go with a shorter Mid/tweet panel 19.5" wide x 18" tall with a 6" floor instead of the 19.5" x 24" with side panels. BDS and my cardboard work showed very little difference between these two designs and the new one had a smaller midrange peak to equalize so i decided to go cut some MDF. First piece - I completely screwed up the recess for the tweeter.. Those damn squares are awfully hard to cut. Second Piece - Ribbon recess came out nice, however I measure the diameter for the PR170 at the face. Turns out it has a slight taper to the frame and the bottom is about 1/16" larger so it wouldn't fit.. I had to go at the recess freehand and its not exactly circular anymore... Oh well call it a test baffle Been listening for the last 2 hours and it sounds awsome.. Picked up even more detail than I was hearing with the cardboard baffles, the sound is incredible, very light and detailed. The measured pretty well too, flat from 20k to 25hz with a slight dip around 250hz (~3db) very sharp too, not really sure where its coming from, can room nulls be that sharp? the total width is like 1/6 octave... Comments welcome, I'm listening to some old school REM right now, Eagles live is next on my play list..
#2 |
#3 |
I'm using a DCX2496 for cross over and delay compensation.
I love the "clamp re-enforced bracing" you've got on there --Chris |
#4 |
Good deal - I'm using a DCX too.
The clamps are only temporary until I install the sides tomorrow. The woofers are the new Dayton Reference subs. They are quite impressive and performing better than I even hoped. I only went with them because the XLS' woofers are difficult to acquire at the moment. Keep us posted of your progress! |
| Mounting speakers side by side | jamikl | Multi-Way | 2 | 6th August 2007 05:01 AM |
| My GC is up and running, side by side with P3A | Jean | Chip Amps | 2 | 21st July 2004 10:38 AM |
| Low side driver as a High side | fr0st | Parts | 0 | 8th May 2004 02:14 PM |
| Side fire sub, how close can magnet be to side? | tim_rule | Multi-Way | 2 | 2nd February 2003 08:22 PM |
| Page generated in 0.07969 seconds (71.35% PHP - 28.65% MySQL) with 10 queries |
