Old 25th September 2005, 09:47 AM   #1
Default Please help
My dad has a pair of Cerwin Vega "AT-10" floor standing speakers, in which the surround on the 10" drivers are deteriorating and litterally falling apart.
I would like to replace the 10" driver, in which I need to know the crossover frequency/slope of the CV 10" driver, since we will be using the existing 3-way crossover.
I can not locate a PDF manual for these driver, nor can I find anything on CV's website.
I did find a set of the "AT-10's" for sale on ebay with the following specs listed (can anyone confirm they are correct?):
Specifications:
Freq Response: 30Hz-22kHz
Power Handling Capacity: 5/125 watts (min/max)
Sensitivity (1w at 1M): 95dB
Nominal Impedance: 6 ohms
Distortion (midband at 96 dB/M, THD&IM): 0.6%
Max output level (pair at 3M, full power): 116 dB
LF driver VC size: 1.55"
Low freq driver: 10" cast aluminum frame
Mid freq driver: 5" cone
High freq driver: 1" mylar dome
Crossover freqs: 400Hz/3000Hz
Connections: low resistance push terminals
Protection: self-resetting circuit breaker for tweeter
Level controls: tweeter, midrange
Enclosure type: bass reflex
Dimensions: 28.5" x 14" x 13.5"
Gross Weight: 40lbs (each speaker)
Assuming the stock 10" driver is LP at 400hz, will the crossover frequency and/or slope change if I were to replace the CV 6ohm driver with a new 8ohm driver?
Thanks, Dave
Old 25th September 2005, 10:21 AM   #2
barfind is offline barfind  Australia
Hi FR, have you thought about repairing your drivers. There are a few sites around that sell kits for most drivers.
http://www.decware.com/newsite/mainmenu.htm
Have a look at this site, maybe give them a ring, very helpful
Nigel
Old 26th September 2005, 06:07 AM   #3
I was hoping for an excuse to buy new drivers
I might go that route though, thanks for the link.
Dave
Page generated in 0.05827 seconds (83.19% PHP - 16.81% MySQL) with 9 queries
