Old 26th September 2005, 03:59 AM   #21
paulspencer's Avatar
it's not only the low frequencies that come around the baffle though, pushing the low frequency diploe rolloff down below the audio range is fine, but above that you still have higher frequency back waves bouncing around the room interacting with the front wave. Assuming it's a round baffle (as using a single number for D does) you get a comb filtered high frequency response, and still figure of 8 radiation pattern right?
I don't see much point in arguing the merits of a true infinite baffle vs one with an fequal at 20 Hz, since the latter is not practical to fit into a room which is of a size that benefits most from OB.
If you wanted to discuss a practical OB vs IB, then you would have to consider things like polar and power response, directivity and room response, excitation of room modes, imaging and room treatment, SPL requirements, driver choices, room modes ........ it would be a very in depth discussion. The ideal would probably be a combination of the two, with OB being the winner from 40 - 200 Hz, IB below that and for the treble. The midrange would be the most likely range of contention over which is better. Those prefering IB midrange would perhaps use a waveguide for the treble and select a larger mid driver to get some pattern control.
For a dedicated room, I'd be interested in a Linkwitz Phoenix main panel with 4 x SS 10" added to the main panels like in the Beethoven, and dipole woofer array either side, with an IB sub operating below 40 Hz.
Old 26th September 2005, 10:54 PM   #22
poptart is offline poptart  Canada
poptart's Avatar
Fair enough. I just don't see any reason to try and connect infinite baffle and open baffle, an infinite baffle is much more like a giant box speaker than a giant OB. The argument would be irrelevant to the original poster's question too since his design has a small open baffle for the mid+tweet on top of a box, Bazzilla style, nothing to do with large dipoles or infinite baffles.
Old 27th September 2005, 01:26 AM   #23
j.burtt is offline j.burtt  United States
Thank You.
ESL in infinite baffle hugobors Planars & Exotics 9 15th March 2008 04:22 PM
Aperiodic box for B200. Vent size and box shape? ChuckT Full Range 11 15th October 2006 07:29 AM
Help with infinite baffle. Andrew S- Multi-Way 2 8th February 2006 03:53 PM
help w/ infinite baffle sub HIPCHECK Subwoofers 5 16th December 2005 12:19 AM
Infinite Baffle. Best bet if possible? Hybrid fourdoor Multi-Way 50 9th July 2004 08:52 PM
Copyright ©1999-2013 diyAudio
