#81 |
Trying again to attach file.
Bjorn |
#82 |
Hi Bjorn
Thanks for that - that at least pretty much confirms what everybody here has been "suggesting". I don't like to make definative accusations without evidence - however it does appear to me now probable that the figures displayed in the AudioXpress article are not fully representative of a standard anechoic response. We have heard it from the horses mouth as it were. Catapult - The fact that the port is a rear firing port places it further away from the microphone, impacting it's effect on the response doesn't it? Anyhow thanks for being insulting. Planet - "Give catapult the benefit of the doubt". Sorry but I don't like to operate on doubt. I like to operate on facts, which I think we now have unless Joe himself would like to come on here and explain the reason for any difference (Prehaps - Bjorn would like to invite him I would also like to suggest that Seas add an addendum to their description of the Thor on their site explaining these disparities between the graphs. Possibly even add the graph that you have displayed here Bjorn?
Ross Saunders |
#83 | |
The bass frequencies coming from the open end will travel in all directions, the response should be almost the same as a front firing open end. I think the placement of rear mounted ports, or open ends of TL's, is done primarily to help suppress midrange leakage and maybe to try and get more room coupling of bass frequencies with a rear wall. |
#84 | |
#85 |
35 cm / 1m / should amount to a couple of db, but I agree with you the confirmed port output is so low anyway it won't make much difference.
BTW - thx for making those sheets available - can't remember if I aknowledged that in all this commotion.
Ross Saunders |
#86 |
Fez - I suppose it can be seen from both points of view. My point is that a rear mounted port will show a different response plot to forward mounted. with the same speaker even though both of the driver and port are radiating the same signal in both instances.
The question is how does this relate to room response. A rear mounted port would generally provide a higher level of bass and to give the viewer of the graph that information, the port can be adjusted to relfect that.
Ross Saunders |
#87 | ||
In my experience, testing a speaker and getting accurate and usable response plots is much more difficult then designing and building the speaker. The only test data that I pay attention to is data accompanied by a detailed description of the test set-up, the raw data, and then the steps used to post process the data, including all settings applied in the measurement software, to produce the final plot for presentation. A single plot without this back-up information can be very misleading. Testing is tricky and requires great skill and understanding. |
#88 |
This is how Joe D describes he did nearfield driver measurements:
"In practice, the near-field response of each woofer is measured separately with the other woofer shorted, and then both responses are added to get the total low-frequency response of the woofer pair." My understanding is he measures the nearfield of each woofer driver separetely while blocking the other woofer by short circuiting its terminals, then adds the two together. I don't know much about TL's, but wouldn't this cause error? By not driving the other driver, the effective volume behind the driver being driven will be doubled from what it is in real usage, wouldn't it? |
#89 |
Yes! Excellent point.
It would be like putting two drivers in a closed box and measuring the response of each separately. Each driver would see double the volume it would physically see if both were operating together. For a TL, the bass response would be much better then reality if it were measured this way. |
#90 |
Compare the calculatued response plots in posts 13 and 57.
Post 13 - two drivers running together in the Thor enclosure. Rolled off bass as has been reported by a few people who have constructed the project. Also, closer to the SEAS measured response. Post 57 - one driver running in the Thor enclosure. Nice deep flatter bass, closer to the measured plots presented in audioXpress. Maybe both inputs are correct, calculations and measurements, for the conditions in which they were obtained. Unfortunately if this trail of logic is correct, the actual speaker response is closer to post 13 which is not that great for a TL enclosure. |
| Seas Thor vs Seas Excellence | phillfyspoon | Multi-Way | 1 | 31st March 2007 07:24 PM |
| seas thor?? | twenty | Multi-Way | 8 | 20th August 2006 12:22 PM |
| Page generated in 0.12833 seconds (79.43% PHP - 20.57% MySQL) with 11 queries |
