Clarity on Seas Thor Kit
Old 27th August 2013, 01:11 AM   #1111
Renron is offline Renron  United States
Renron's Avatar
8ntractor,
Thank you for the very kind words. I warned you about finishing the cabinets........LOL. Too funny.
I am just a termite, making little pieces of wood out of big pieces. Dave (Planet10) and Sir Scottmoose are the heros of this speaker transformation.
James5000,
I'll try to answer most of your questions in the order you asked them. Easy to be overwhelmed with information from so many credible sources.
First, I'd charge (even a friend) more than a few "Fosters" for the trouble your about to take on. (hint: don't offer to paint them piano black) LOL you'll be sorrrrrrryyyyyyyy!
Second, the "Kit" that is sold on line is CRAP. That is what Planet10 and ScottMoose worked so hard to correct. The XO (crossover is crap too)
There are currently 3 versions of the "Thors" that have had the design corrected.
The Small, The Fat and The Short. I built the "Small". It has great WAF appeal.
Here is Planet10s website with the dimensions and a good XO design by Jimangie. I can vouch for this XO, it helps. Reduces the Db a few from the original design but is worth the attenuation.
http://frugal-phile.com/boxlib/Revis...hor-291109.pdf
Mount the XO on the OUTSIDE of the cabinet. I originally built them inside and then later changed to outside. MUCH easier to change a C or R.
Either Baltic birch plywood (has more layers and zero voids) or MDF. MDF makes lots of nasty dust. I used Italian bendy plywood for mine. Either is OK.
Use lots of bracing internally and butt joints are fine with a good quality glue. You know which one you prefer. Hard to over brace the box. Until you start to negate the internal volume. Use whatever type of jointery you prefer. You can locate the port in the front or down, if you put it in the rear, it will sound boomy placed near the wall. Dont' do it!
Planet10 already has drawing posted (above link) , but we would like to see your progress as you build them. Start a new thread with your build pictures and questions, put a link in this thread so we can find / follow your progress. We answer questions more often when pictures are involved. I'm sure 8ntractor will be a fountain of knowledge and glad to help you with your build questions.
Ron
Still lovin' my Thors. Thanks Dave and ScottMoose!
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 27th August 2013, 05:25 AM   #1112
8ntractor is offline 8ntractor  Canada
Hi Ron,
You, Scottmoose and Dave forgot way more than I will ever know about this. I am happy with my first build and they will likely be my last because they are good enough that I will live with them for a long time. I kept my b$w's for a decade and these are superior. I was playing around with them after bolting the drivers in and i inverted the tweeter polarity I also used a speaker location calculator "rule of 5ths".and put them on hockey pucks (this is canada after all) they always sounded good but now they really sound good. I finally got around to measuring the speakers today with a cheap radio shack spl meter and a computer generate sine wave sweep. +/- 3 from 42 - 20k at the listening position. I am sure the measurement was not super accurate. but the band is in the room.
Ben
Old 3rd December 2013, 12:13 AM   #1113
spedmetal is offline spedmetal  Finland
Hi all,
Im thinking on rebuilding my old Thors. I have few questions. What is the difference between Fat Thor and Fat Thor ML sound wise? I really like the old Thor for the not boxy bass and mid. So am I wrong to think that Fat Thor would be better in that region?
Then about the crossover. Ive found a couple of schematics for a new xo. One on the link on Renrons post above and this one:
http://www.diyaudio.com/forums/attac...-crossover.jpg
Is the latter one the latest version from jimangie1973 and can it be used on Fat Thor?
Thaks in advance
Juhi
Old 3rd December 2013, 12:50 AM   #1114
Renron's Avatar
I have not heard either the Fat Thor or the Fat Thor ML versions of the design.
I would guess, it's only a guess, that they would sound VERY similar. Pick one! You'll be happy.
Can't help you with the XO question, sorry. Send Jimangie a PM.
Ron
Old 2nd February 2014, 08:48 AM   #1115
xa1976 is offline xa1976  France
xa1976's Avatar
Originally Posted by planet10 View Post
I backed off on the percentage after seeing yours and greenie's swisscheese. You want to use the holes to let air flow freely, to break up resonances, but not so many that they compromise the structural integritiy of the brace. Some of ours likely get as low as 30%.
dave
Hello,
I build "small thor" I read the whole topic but I had to miss this passage.
I think I removed too much when I do my swiss cheese .. : ( what will be the impact on the final result, is it serious?
Thank you in advance for your answers.
Old 10th August 2014, 02:33 AM   #1116
cjrtrio is offline cjrtrio  United States
Default Want to best PMC Twenty-13 TL speaks with Thor DIY
Thor Gods:
I won’t do this to you again – I promise.
With DIY Thor on my mind, I went to a shop wherein the next-to-cheapest tower speaker is the $5k/pr PMC Twenty-23 (transmission line 2-way speaker, 5.5 driver, SEAS doped fabric tweeter, crossover at 1.8kHz). They were powered by a ProLogue Premium tube amp – the salesman said the amp sounded like the HK Citation II which I’m preparing to rebuild McShane-style with help.
I was (finally) really impressed by a speaker (lots of buddies have had extravagant fails over the years). My yardstick is carved bass (I’ve played some $6-figure ones). LaFaro’s bass from Bill Evans’ Village Vanguard gig in 1961 sounded like it was there playing in the store…and not the least bit puffed up or ill-defined. An in-store copy of Beethoven Opus 13 on solo concert piano sounded like a, um, piano…not a piano with hidden Kraco subwoofers. Diana Krall’s voice (including s consonants) was real and devastating and her piano sound was proper (her string bassist’s sound was a bit produced-up but no matter – Mr. Costello’s wife gets a lifelong pass from me for reasons I shouldn’t discuss here).
I dutifully listened to some modern fictionalized sonic perturbations too (Steely Dan, Michael Jackson, other stuff) – the 23s recite them tactfully and dispassionately which is fine with me. I might go back and hear some tenors, sopranos, guitars, trumpet/sax, etc. (and some Cavaille-Coll-spec pipe organs although that’s admittedly not fair).
I was out of time and won’t listen to speakers I can’t afford, so that was it. If a speaker does the above-mentioned acoustic stuff adroitly, I’ll put up with the rest. Note that the PMCs weren’t at all loud - I would like to have more headroom so that I can work on the motorcycle in the garage and have it sound like a hired trio is just inside my screen door.
So…Thor and diy. I’m thinking I’m a budding transmission line apologist. I like super-controlled bass and TL apparently gives it (so does CII – if my friend hadn’t sold his wheels-up CII to me for chump change I might not be going here). In this thread I detect the notion that the original Thor design, an already “bassically” well-behaved design, has perhaps been bested bass-wise by the fat, small, short, etc. derivations (an unusual anti-Goldilocks result).
I have a professional woodworking guru with a shop full of expensive machinery in the building next to me. I’m not looking for Museum of Modern Art chic looks - I’d wouldn’t mind if they looked as if a super-talented Amish person had made them with primo materials and old-school techniques, dowels, etc. (Maybe imagine them next to the whale foreskin covered barstools in Ari Onassis’ yacht in the 60s…yeah). I like the look of the SEAS MTM Thor stuff (not very Amish, but never mind, move along). And I want to know going in that my cabs are heavy and steadfastly out of the sonic picture – I will get young athletes to move them around for me.
So, thou studly experts whose brains I dig, hit me with your rhythm stick. Please post replies and sell me on:
Fat/Thin/Small/Original/Extra-crispy? I want extended/controlled bass with playback volume. Since the CII is already controlled in bass, perhaps I can afford some extension on original Thor bass? These will play in a large room with hardwood floors and a vaulted ceiling (or a smaller room if my current romance doesn’t work out – again, move along). And, um, now would be a good time to suggest any other tight-bassed diy design option.
SEAS? – They’re purdy, SEAS has long-term corporate stability, the build quality is seemingly worthy of the CII. But I’ve described my sound – is there a better TL option?
Crossover?:
I want to shave down any known bumps using highest-spec parts and defensible design. Looking for smooth, low-fatigue trio jazz ride cymbal (test: Thigpen’s ride on Oscar Peterson’s West Side Story). Want no mendacity in vocals – e.g., Krall’s voice must not acquire any fork-tongued sibilance. Crossovers will be external - I am prepared to experiment. No compromise - if you tell me I need whale-foreskin-in-virgin-olive-oil capacitors, infra-hydraulic quasi-toroidal transformers, well ok.
Cabinets?:
I dunno – Zalytron for heft? Or completely custom and let my cabinet guy figure it out s/t interior dimensions? I dunno.
I do know this – though this is important to me and I’m excited about it (and have been), I’m done thinking about it and will not drawl on any longer – I want to get some choice basic intel subject to my proclivities and DO it. I’m a blind golfer here and you’re the pros – please line me up on this drive and I’ll get myself to the 19th hole.
I won’t do this to you again – I promise…even though this thread is already epic.
CJRTrio
Old 11th August 2014, 03:29 PM   #1117
Well I'm no pro, but I've been living with Thor´s for a few years now.
I built new XO´s for my Thor´s some time ago, and I really like the result. Being lazy, I haven't built new cabinets. Fat would be my choice, but my next project is a 4-way phone booth, so Fat Thor must wait its turn.
The Thor is a very good speaker. Specially mid clarity and bass control are superb in its price class. No boxy sound here.
Thors are not a hard speaker to drive, but they do benefit from a good amp. I substituted my old Luxman with a pair of Apoll class-d mono block´s and could not stop giggling for hours.
Juhi
Old 19th August 2014, 03:53 AM   #1118
Juhi-
Thank you for that. I am canvassing my wood savvy friends for ideas. I'm sure I will love them like children.
Looking forward to giggling.
Old 19th September 2014, 08:08 PM   #1119
troystg is offline troystg  United States
troystg's Avatar
Dragging out from the dead... :-)
Does anyone have any pics ofthe cabinets made from Corian? Appears the link is dead now.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 4th October 2014, 07:29 PM   #1120
Renron's Avatar
CJ,
I've been gone (other forums, not audio) for a while so I just read your verbose post and related questions.
Your not going to like the sound reflections from those hard wood floors. Been there, used area rugs to help (not cure) boominess. Ports on the front or down? Mine are on the front, if I had a do-over, I would port them down. How far from rear walls can they be placed and you still be happy with room design. Curtains? Rugs? Chairs? Couches? All will make an impact on the reflections and Boom you perceive.
Fat thors will produce copious amounts of bass, maybe not the best for your locations and taste. (hardwood floors)
Tall Thors would be a good match, imo. All of the umph but controlled.
Solid cabinets are a must. Build 'em right and you'll be grinning like the rest of us soon.
Let us know what direction you go.
Ron
necro-posting specialist.......
Clarity on Seas Thor KitHide this!Advertise here!
Seas Thor vs Seas Excellence phillfyspoon Multi-Way 1 31st March 2007 08:24 PM
seas thor?? twenty Multi-Way 8 20th August 2006 01:22 PM
