Old 18th February 2012, 03:02 PM   #1071
jackinnj's Avatar
Originally Posted by JC View Post
I haven't tried switching the tweeter polarity, but if the woofers and tweeter are in phase at the crossover point (which I think they should be given the sims and measurements posted elsewhere in this thread), shouldn't you get a giant suckout at the crossover frequency when you switch polarity? Has anybody done measurements with this change?
I lent out my XTZ, and in any event will have to wait until the weather gets warmer!
Old 20th February 2012, 08:35 AM   #1072
KarlXII is offline KarlXII  Sweden
KarlXII's Avatar
This is typically what happens when changing polarity on the tweeter:
Old 21st February 2012, 01:46 AM   #1073
JC is offline JC  United States
That's what I would expect, except at a lower frequency since Jim's version crosses over below 2000 hz.
Old 21st February 2012, 11:02 AM   #1074
jackinnj's Avatar
the 4.5kHz peak in the original curve is a mechanical artifact of the woofers used in the Thor.
Old 20th March 2012, 09:39 PM   #1075
Default Thor ReRloaded
Hello there,
i quite like the thor and this thread, and i am wondering if any of you have seen, or better heard this Transmission line version of the thor, published in Hobby Hifi, 2004/04 ?
looks promising ,
cheers
Yurgs
Old 20th March 2012, 09:47 PM   #1076
I have never heard of that version. How is it different?
Any technology sufficiently advanced is indistinguishable from magic
Old 20th March 2012, 10:03 PM   #1077
I am not quite sure,
looks like they did a mod on the xover as well, the alum panels at the front.
They also mention that the dip in the freq response is caused by the shape of the frontpanel around the tweeters (so rounded edges should fix it).
apart from that it looks the same to me.
Old 21st March 2012, 12:47 AM   #1078
Renron is offline Renron  United States
Renron's Avatar
Any Idea what the physical size is? That is what made the most difference.
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 29th March 2012, 08:10 PM   #1079
They kept the size the same, just the phase on the outside of the cabinet was added.
Old 19th April 2012, 06:14 AM   #1080
Byrd is offline Byrd  South Africa
Send a message via MSN to Byrd
I have finally been able to carry out an FR plot. This is for the Small Thor with D'Apollito crossover. As has been stated before there doesn't seem to be any problem with suppression of the hf resonance in the magnesium cones.
Ross Saunders
Seas Thor vs Seas Excellence phillfyspoon Multi-Way 1 31st March 2007 07:24 PM
seas thor?? twenty Multi-Way 8 20th August 2006 12:22 PM
Copyright ©1999-2013 diyAudio
