Clarity on Seas Thor Kit
Old 30th September 2010, 04:39 PM   #1011
jackinnj is online now jackinnj  United States
jackinnj's Avatar
Originally Posted by ichiban View Post
I'm not seeing A graphic here, should there be one?
Also, never got a response to post#1007.
The new XO was referenced on Madisound's forum to this thread at HTGuide forum -- it's on the 5th page:
HTGuide Forum - seas thor crossover redesign help
http://www.htguide.com/forum/attachm...chmentid=10703
D'Appolito designed the original LPF section to deal with the rising response of the paired woofers at around 400Hz, and a resonance at 4.5kHz with a 10dB peak. Perhaps Dave can opine, but the suggestion was made that the peak was dealt with "inadequately". I don't see this to be the case with the original XO's.
The 8 ohm resistor in the impedance matching network of the HP on the new design is too low a value.
Old 30th September 2010, 04:58 PM   #1012
jimangie1973 is offline jimangie1973  United States
I'm totally confused as well...
Old 30th September 2010, 06:38 PM   #1013
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Jack,
This is on you very wide build of Thor?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th September 2010, 07:27 PM   #1014
jackinnj's Avatar
Originally Posted by planet10 View Post
Jack,
dave
The front is 9.5", but bevels at a 30 degree angle. The dimensions were worked out on the MJK Mathcad program.
Old 30th September 2010, 08:37 PM   #1015
frugal-phile(tm)
planet10's Avatar
The end of the bevels will determine the effective width. Being much wider any BSC comp built into the XO will be thrown way off (ie in theory you should get a big hump below about 500 Hz)
dave
Old 1st October 2010, 09:10 PM   #1016
jackinnj's Avatar
dave
The original XO from the AX article just used 1mH as an LPF.
Here's a screen dump of the 4.5kHz corrector's effect from the AX article -- it is "inadequate" as suggested:
Old 2nd October 2010, 05:41 PM   #1017
jackinnj's Avatar
I worked backwards with a BSC Calculator, determined that the effective front baffle width was about 11 inches -- here's a screenshot with (lower green trace) and without the correction (1.5mH in parallel with 3.7R):
Edit: This is the XO from the AX Article
Old 17th October 2010, 01:17 AM   #1018
JZatopa is offline JZatopa  United States
Just curious if anyone has had a chance to listen to the the Thor and gedlee's speakers. They are two different ways of doing the same job but I am curious to hear how they compare considering these two kits seem to be the top of the DIY kits available today.
Old 31st October 2010, 09:38 PM   #1019
HiFi Si is offline HiFi Si  New Zealand
A bit of a late question - I hope that this thread is not dead!
I was a bit of an early adopter of the Odin and built the early design with the W17-E002 drivers and Millenium Tweeter. I went with a xo design that was faxed to me by Seas USA, upon an advisory from Madisound about concerns with the original design. I also upgraded to Alphacore Inductors and Sonicraft caps..
I am keen to try Jim's design, but of course I have the question about compatibility with the W17 drivers, which have slightly different T/S parameters...
Does anyone have any advice on this?
cheers
Simon
Old 3rd December 2010, 01:59 PM   #1020
hhildebr is offline hhildebr  Germany
Jim,
is that a new version of your redesigned Thor XO? Or does it just work with the Odins? The topology seems identical but the values are very different from what I know (e.g. 8.7/22 uF in series with the tweeter rather than 5.7/18).
Thanks,
Hauke
Clarity on Seas Thor KitHide this!Advertise here!
Seas Thor vs Seas Excellence phillfyspoon Multi-Way 1 31st March 2007 07:24 PM
seas thor?? twenty Multi-Way 8 20th August 2006 12:22 PM
