Hi guys just wandering if someone can give me info on these 2 woofers(PL18WO-09-08 and XG18WH00-08), i am planning on building a 20-23L ported box tuned at around 40hz using one of these drivers and i need to mate it with the XT25TG-30-04(already got the tweeter). I am after sound quality as well but i would like to stay with a choice of these 2 drivers if possible.Im trying to achieve sound quality to dollar value as these drivers are not too expensive but seem to be of quite a good quality. Just not too sure whcich will work best with the xt25. Absolutely any info would be very appreciated.I would like to keep it the same brand too if possible. But will gladly take any advice given to me seriously.
Regards Bowdown Keep up the diy spirit |
#2 |
Those wood pulp drivers will have a definite rise before you get up to the tweeters crossover point. I had that wooden drivers already. They look cool but i dont think they are all that practical in a 2 way. Thats an opinion by the way. I never did put them in a box and play them for 2 weeks so i could actually hear what they would sound like. I just Modeled them.
Persistence is better then intelligence. Unless persistence kills you. |
#3 |
Account Disabled
You're in luck
Good design all figured out (best for people without measuring equipment IMHO) http://home1.stofanet.dk/troels.grav...x_b/PL18XT.htm |
#4 |
Oh wicked guys thanx heaps for helping me out, gees that link is probably just what i was looking for. Has anyone ever had a listen to that configureation? I guess i should just buy the PL18 woofer.
Thanx again regards Bowdown Keep up the diy spirit!! |
#5 |
Hi guys sorry its me again i was looking at one of these 2 way systems and was wandering which one would be better?
http://www.partsexpress.com/projects...la/nebula.html and the Korrekt from this one http://www.audiocomponents.nl/speake...t-line_eng.htm I look at the one that tktran posted but worked out to be too expensive due to so many cross over parts. Please Please help. Regards Bowdown |
#6 | |
I vote for the Troels Gravesen design, at least its certain that he knows what he is doing. Besides the vertical axis of the SPL graph has a range of 180 dB !!!!!!!!!!!!!!!!!! |
#7 |
the PL18 is a very nice driver, but to my opinion the 17WN225-8 is even better (and cheaper too), because it was build with midrange purposes in mind. It features a very leightweight moving system and a nearly perfect roll-off and step response. This helps keeping the crossover very simple. I build a box using two of those and the XT25. Because the XT is bit too low in SPL for this, I had a spherical horn made from massive aluminium. The very positive effects were, that the SPL of the XT went up to a 100dB@2kHz with an constant tilt towards the upper frequencies. This leads to smaller values in the crossover, as well as reduced distortion and higher dynamic range. The horn is loaded up to more than 15kHz with a nice roll off above. People said, they hardly ever heard the XT soo smooth but so dynamic alltogether. An additional effect is that the Tweeter is 38mm ´behind´ the woofers, which gave an excellent overall step-response! The box has an SPL of 93db/2.83V/1m and is intended to be postioned close to the wall, for smaller rooms and for shorter hearing distances. In rooms greater than app. 25m˛ You should add a good subwoofer. My preferred setup is the new KR-Audio A340 a SE-Triode amp featuring the marvellous KR-300BXLS Triode. It delivers app. 25 of the best Watts You can get :-) Actively crossed over to an dipole Sub You can play levels well above pain with this amp and run this setup in large rooms. jauu Calvin |
#8 |
Impressive project Calvin! Could you post more pics/details ?
#9 |
Speakerholic
Very nice indeed Calvin. Please do post more pics and details.
Cal |
#10 |
the horn for the XT25 jauu Calvin |
| XO for Vifa PL18WO-08-09 and Vifa XT25TG30-04 MTM | knightat83 | Multi-Way | 6 | 24th January 2009 08:51 AM |
| PL18WO + PL27TG Help! | rukkes | Multi-Way | 6 | 4th March 2004 10:30 PM |
| Vifa PL18WO-09-08, MTM | Jolted_Chicken | Multi-Way | 1 | 19th June 2003 01:35 PM |
| a sub from vifa pl18wo-17-4? | leadbelly | Multi-Way | 0 | 3rd May 2003 10:49 PM |
| Page generated in 0.11671 seconds (77.21% PHP - 22.79% MySQL) with 11 queries |
