Where can we buy those sticky resin coating found in ATC speaker units and any substitute could be found?
#2 | |
a lot of speakers have treated cones I doubt I would want to buy it and apply it myself though it can do quite a few bad things if not done right |
#3 |
Any information on these commercial products that can be used and having the same sticky nature after application.
What are the brand names and where can I buy them? |
#4 | |
Another thought is, that whatever they (ATC) use, it's addressing a particular problem that they have with their units. If you're using different drivers then it may call for a different (or no) solution. I'm sorry if I'm not understanding what you want to know, but these are some considerations to keep in mind. Best Regards, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#5 |
infact ,i don't understand what are you doing too !
resin coating are many,some for dome and others for cone. and the industry have their own type,do you think to find the same resin coating of the atc? impossible. regards.
NONE |
#6 |
I would like to play around with this stuff just out of curiousity and see how it influences sound and frequency response and etc...that`s all.
#7 |
I once got a little bottle of this stuff from a guy who used to mod old EV wideband drivers. Even though he was of German mother-tongue he used to call that stuff by the English term "damping compound".
Maybe you will find a source on the web. Regards Charles |
#8 |
If you want to experiment, try doing a search on this site using "damping", cone damping, doping, etc,. Also try the Fullrange driver forum and Audio asylum forums as well. You should get a lot of hits from those. This a subject that has been extensively covered over the years.
Good hunting! TerryO
#9 |
ATC use plasticized PVA and/or Opanol viscous damping mediums.
#10 |
ATC at last reply and solve my problem by selling this damping fluid at the cost of Gbp 23.00 including shipping.
| Coating coated paper cone | Vivek | Multi-Way | 5 | 7th September 2008 08:01 PM |
| resin loudspeaker cabinets | cowanrg | Multi-Way | 52 | 30th August 2006 01:46 PM |
| Coating for Bextrene cone? | Ouroboros | Multi-Way | 0 | 21st November 2005 08:00 AM |
| Case idea to make you resin-ate | Nordic | Chip Amps | 16 | 22nd September 2005 04:19 AM |
| casting resin question | dmh | Everything Else | 8 | 24th February 2005 04:06 PM |
| Page generated in 0.10951 seconds (75.08% PHP - 24.92% MySQL) with 10 queries |
