Building a short line array(4 NSB's) for my garage. Using 1/2" MDF. External dimensions are 7" wide, 24" tall, 12" deep. Will have one internal brace 1/2 way down between the middle drivers bracing the front, sides and rear.
Driver mods are the usual. Rope caulking on the speaker baskets, treated cone and potential hole in dust cover. Power will be from my retired HT receiver. Drivers will be wired for 8ohm. Should I port the box and if so what should that porting be? Remember these are garage speakers that will be heard as I lay under my racecar working on it. I might add some of the buyout tweeters later but no plans right now. |
#2 |
if you ever plan to do any woodworking in the garage, I woulndt be so keen on making a hole in the dust cap. Its there for a reason. (keep dust out of the gap) In an environment like the garage, I would think there would be more dust and other things that could potentially get into the voice coil/gap than in your typical listening environment.
#3 |
Thats a good point. I was going to do the mods listed on PE for the NSB. I'll skip that one. I imagine laying under my car I won't be able to tell a difference.
With that(carpentry dust) in mind should I skip the port and live with what I get from the sealed enclosure or will it make that much of a difference? |
#4 |
If the port was rearward ro downward, i wouldnt worry about it. If there was ANY stuffing in between the port and the driver, i guaruntee no dust will make it to the voice coil. There is also the woven spider in between the air and the voice coil which acts a a bit of a filter.
#5 |
The best NSB mod is cone treatment. Try 4 thin laquer coats.
Don't mess around with any other mod unless you think you need to solve a specific problem. Porting NSB. Try a 2 cubic foot box for all four NSB's, tuned to 85hz. Rear port will be a ~ 5.75" hole approx 1/2" port length which happens to be the thickness of your wood. If you use 3/4" wood, cut a 6" hole. You can always place another piece of wood on the back with a hinge to close the port and make it sealed to tame some of the boomier upper midbass. If you can't do 2 cubic foot, only 0.8 cubic foot, then tune it to 110hz with a 4" hole cutout in 1/2" wood. It's not as good as the 2 cubic foot idea but you still have the option to plug the port. |
#6 |
I was actually thinking of doing the same thing for my garage. How good do the NSB's sound anyway?
#7 | |
pretty good actually |
#8 |
I really need to finish my NSB line array. For me, wood working is just so much, well, work.
From a little carboard test baffle I made, the NSB's really dont sound like a .49cent speaker. Not spectacular, but a good cheapy speaker. |
#9 |
NSB's or any driver in an array may sound better as distortion is
lower for the same SPL as the single driver, ie an NSB alone is not exactly a low distortion design and when you push it hard, you can hear distortion if you have a good ear. But place alot of them in a line array and you can operate each NSB at reduced output giving you very clean sound and the line arrays boosts output to allow higher SPL. If you wire them for low impedance, more sensitivity - hehe You really see the benefits when you do big line of NSB vs. a smaller line. My 5 NSB test box is no match for the line of 16 I made. If this is for a garage stereo, then go bigger like this. No need for anything fancy, just do a small sealed tower. http://www.caraudioforum.com/vbb3/sh...d.php?t=225275 Try it without a tweeter to save some cash. |
#10 |
Thanks thylantyr. I might do the 9 NSB array. I've got room for it, the wood for it and ofcourse a box full of NSB's. Its not much more work except for the routering of the holes.
| line array + transmission line ? | zobsky | Multi-Way | 12 | 16th August 2006 04:18 PM |
| Line array tweeter line - On left or right? | dhenryp | Multi-Way | 4 | 9th March 2005 11:35 PM |
| does a line array need a sub? | scone | Multi-Way | 10 | 10th November 2004 06:40 PM |
| how to combine Line array and transmission line together | Jared | Multi-Way | 5 | 19th April 2004 10:32 PM |
| t-line subs for a DIY line array | tom1356 | Multi-Way | 17 | 28th December 2002 12:15 AM |
| Page generated in 0.09199 seconds (87.29% PHP - 12.71% MySQL) with 10 queries |
