Hi, i was hopping someone could help me.
I have a 12" speaker in a vented enclosure driven by an alesis ra150 amplifier and have been using it for the base output from my PC but what has been happening is that i keep getting poping sounds coming from the driver at random intervals. This occurs any time wether the signal is loud or quiet. What could be cousing the popping? Thanks for any help Danny (Link for driver info: http://www.bkelec.com/HiFi/Drive_Uni...bsbl12-100.htm) |
#2 |
A cellphone laying nearby can cause that. Beyond that, it could be a lot of things ... try re-configuring your setup to try to isolate the offending piece of equipment (amp, computer, etc.).
#3 |
hard to say, you need to be systemmatic and eliminate possible sources of the sound. Is it related to the driver movement? What if another driver is used?
AUDIO BLOG | Bass integration guide My work: www.redspade.com.au web design studio |
#4 |
using xp? change the start sound file? it make click clkick on small speakers, like when you click a link on the net... but it makes a horible click when connected to big speakers...
#5 |
gday!
try to use another sourse of sound first, not computer. some CD, or.... is it ok? change driver for your sound card as well.
Artmaster live in www.artmaydan.org.ua |
#6 |
I have tried different setups and the popping sound does not stop. Though sometimes there will only be one pop in certain amount of time or there are several other times.
#7 |
there might be a loose/dirty connection or a dirty volume pot.
#8 |
take signal from CD directly (on front panel)
#9 |
Something else that has been known to cause a pop is a refrigirator. When it switches on and off (the compressor that is) it could cause a popping sound. I would suggest maybe trying a cheap DIY mains-isolation tweak.
Deon
Reality is not digital, an on-off state, but analog. Terry Pratchett - Moving Pictures |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| "Good" quality in-ceiling speaker supplier from china | swak | Multi-Way | 0 | 23rd February 2009 07:43 PM |
| Braided speaker wire "filler", kimber weave directions | jmb14731 | Parts | 3 | 4th June 2008 10:23 PM |
| DIY "speaker box" ("BOOM BOX"). Help needed. | MASantos | Full Range | 6 | 2nd September 2007 12:00 PM |
| 10" basS/mid for "party-speaker" | TroelsM | Multi-Way | 0 | 16th September 2005 11:14 PM |
| Page generated in 0.08056 seconds (86.82% PHP - 13.18% MySQL) with 10 queries |
