Request - some advice on selecting an amplifier for tweeters.
I am currently building a 3-way system with active xover (24db Linkwiz). For the woofers (bass/mid) I use an old Quad 405 (recently restored) and a newly build Hypex UCD180. For the tweeters I currently use an old small NAD. It is the latter that has to be replaced. I imagine something with emphasis on quality rather than power – e.g. 20W high quality, preferably DIY. Any suggestions - Zen, Mini-A..........? The tweeter is Vifa XT 25, the woofers are Vifa PL14 and PL22. __________________________________________ time flies like an arrow ... and fruit flies like a banana |
#2 |
HAve you ever tried the Hypex on the tweeter and the NAD on the midrange ? It might sound strange but I have heard it a couple of times on active systems that it sounded best with the most powerfull amp on the tweeter.
#3 |
Yes, in fact I have, and it sounded fine in the treble, but the NAT is a very old piece of equipment and I find it very hard to assess the treble without equal high quality midrange. So no conclusion on that occasion.
But you got a point, the Hypes is easy to work with and is extraordinary god value for money. High power for tweeters hmm……… maybe it is demand high power in a short time? Maybe large caps relative the transformer is the answer (e.g. an UCD 180 with 125VA/20.000uF). Let me elaborate a little on my considerations.- A 4th order Linkwitz xover ads a lot ringing to pulses so the power amplifier should not ad any thing to that at all (distortion) - Hypes is god value for money because of the relative high power (beside high sound quality) – if, however there is an amplifier concept with special treble quality, at the cost of power it might be ideal. __________________________________________ time flies like an arrow ... and fruit flies like a banana |
#4 |
I have bad experience with mosfet on tweeters, and good listening experiences with tube amp for tweeters. How about Gainclone? I don't like the bottom end of Gainclone, so it may tell that the treble is okay?
#5 |
frugal-phile(tm)
The way Julian Vereker put it (over beers in Chicago one CES) was to put the highest quality amp on the top (ie if you could only afford 2 NAIm 160s & a NAIM 250, then put the 250 on top -- not because it had more power but because it was a better amp)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#6 |
So far, so good - you are confirming my thoughts, but I guess I just want it all, high quality and low price.
#7 |
frugal-phile(tm)
For SS a miniA might be a good choice... I'd worry less about the rated power than its synamic capabilities.
dave
#8 |
How about Nelson Pass PLH or Elliott Sound’s 10W class A http://sound.westhost.com/project10.htm?
Neither seems to be offering PCB, can anyone suggest a suitable pro-ject with PCB or a complete kit?
| Advice on new amplifier | j.videtich | Solid State | 6 | 4th April 2008 01:28 AM |
| New Inf. Primus 150- dead tweeters in both - advice needed | nyindallas | Multi-Way | 1 | 1st August 2007 12:18 PM |
| Need some amplifier advice | Fast1one | Solid State | 5 | 24th January 2007 05:16 PM |
| Want to switch out tweeters in axiom M80s, need advice/help/flames etc etc | VisionxOrb | Multi-Way | 4 | 24th January 2005 06:01 PM |
| Amplifier Advice | fr0st | Solid State | 5 | 28th December 2002 12:35 PM |
| Page generated in 0.09983 seconds (81.45% PHP - 18.55% MySQL) with 10 queries |
