Old 20th September 2005, 06:27 PM   #1
andy2 is offline andy2  United States
Default Driver Electrical equivalent circuit to design xover
Anyone knows a website or documention to calculate an electrical equivalent circuit? I need to design some xovers but I don't have the design software.
I just need the equivalent circuit to calculate 3db point ... and so on.
Old 20th September 2005, 07:21 PM   #2
Svante is offline Svante  Sweden
Svante's Avatar
Is this what you need? Mm is Mms, Cm is Cms and Rm is Rms.
Also note that Le usually doesn't behave exactly like a normal inductance.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 20th September 2005, 08:03 PM   #3
Thanks. I'll try that.
Old 21st September 2005, 12:28 AM   #4
Svante,
On the schematic, Mm is inductance and Cm is capacitance, correct?
Old 21st September 2005, 08:13 PM   #5
Svante's Avatar
Originally posted by andy2
Svante,
Nope. The mass (Mms) appears on the electrical side as a capacitance with the value Mms/(Bl)^2, and the suspension compliance (Cms) as an inductance (Bl)^2*Cms.
I understand the confusion, since mass is drawn as inductance and compliance as capacitance when using impedance analogies of the mechanical system. But seen from the electrical side, that is what happens (the motor converts the mechanical impedance to its dual network, ie the motor can be seen as a gyrator).
Old 23rd July 2010, 06:25 AM   #6
There is always a first time....
Old 23rd July 2010, 06:31 AM   #7
If this forum is still replied. then just conform.
Mms/(Bl)^2 = Capacitance in farad ( and not like mfd or else)
(Bl)^2*Cms = will give value in henry ( not uh or mh).
Old 23rd July 2010, 12:18 PM   #8
aczern is offline aczern  Poland
http://www.wavecor.com/Transducer_eq...nt_circuit.pdf
Old 24th July 2010, 08:15 AM   #9
Thanks aczern
Electrical feed for using multiple amps in sub circuit Moondog55 Subwoofers 4 1st January 2009 08:28 PM
IGBT equivalent circuit? Arroyo Solid State 0 13th April 2006 01:31 PM
How to design Crossover circuit of the loudspeaker using accuton ceramic driver unit? kevinlin1013 Multi-Way 9 20th August 2005 09:47 PM
Which Thiel-Small equivalent circuit to use? andy2 Multi-Way 9 12th May 2005 11:46 PM
MOSFET equivalent circuit nobody special Solid State 1 13th February 2003 06:12 PM
Page generated in 0.10722 seconds (68.25% PHP - 31.75% MySQL) with 10 queries
