Old 20th September 2005, 12:37 PM   #1
Default Silly question... I used a 50uF cap when measuring my tweeter with JustMLS. But...
...now that I'm trying to use the data on LSPCad, I'm wondering... must I add the effect of said capacitor on the schematic?
Since I didn't model the tweeter alone, but the tweeter with a capacitor in series, how can I tell LSPCad there was a tweeter during the measurements? I have seen this is possible on the JustMLS tutorial, but it's only mentioned - nowhere does it say how can I do it. Is it necessary to add the cap to the model, or can I get away without modeling it?
Thanks a lot!
Old 20th September 2005, 05:16 PM   #2
simon5 is offline simon5  Canada
Well the 50uF cap will do a first order highpass x-over at 375 Hz on a 8 ohms tweeter.
So unless you plan to do a very very low crossover, you can forget about it I guess! I don't think it will change the results much especially over 1 kHz.
DIYaudio for President !
Old 20th September 2005, 07:08 PM   #3
Hi Simon,
Thanks a lot for your answer!
I'm still concerned about phase shift, though. I think my measurements will be wrong if I don't consider the 90° shift.
Maybe I should bite the bullet and take the measurements again, sans cap...
Old 20th September 2005, 07:37 PM   #4
Davey is offline Davey  United States
You're only going to get appreciable phase-shift outside of the passband of the filter. Using the 375Hz, 8 ohm tweeter example the phase shift would only be 45 degrees at 375Hz. It'll be near zero for the area you're interested in. Your existing measurements should be fine.
Davey.
A silly question, but I'm going to ask anyway :-/ TurboFC3S Multi-Way 19 1st April 2009 02:01 AM
Measuring a Tweeter mikee55 Multi-Way 26 26th April 2007 12:59 PM
Yet another silly question! stewartwen Analogue Source 4 17th April 2006 02:19 PM
Silly Question???? Zero Cool Solid State 7 16th October 2004 11:34 AM
Silly question Lisandro_P Everything Else 2 11th May 2002 07:27 PM
Page generated in 0.08375 seconds (71.49% PHP - 28.51% MySQL) with 10 queries
