Old 20th September 2005, 09:12 AM   #1
Geek's Avatar
Default What is the effect of foam on a tuned port?
G'day!
I have a two inch port that I wish dampened to keep the speaker from unloading at the bottom.
The plan is I have some 1/2" packing foam identical to the Y37ch found here:
http://www.foamorder.com/packing.html
As you can see, it's a medium density stuff that breathes pretty good.
Simple question - will this effectively lengthen or shorten the length of tube given me by calculators? Anyone have a ballpark percentage or formula?
Old 20th September 2005, 01:49 PM   #2
GM is offline GM  United States
GM's Avatar
Greets!
It does neither per se, though it does roff off the vent's output, ergo moves the cab's alignment towards a well damped sealed one. No simple rule-of-thumb I know of beyond ~2 lbs/ft^3 stuffing density using R-19 fiberglass insulation is the audible limit of change to my ears.
You can plug your design into MJK's PORTED WS and try different vent stuffing densities, though its sim is based solely on his research using polyfil.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 20th September 2005, 02:03 PM   #3
Geek's Avatar
Many thanks for the info!
Technically, this experiment in a "happy medium" between bass reflex and sealed is for a full-ranger, so the complete results will be posted there when done.
The answer to this ties my last loose end.
Cheers!
Old 20th September 2005, 05:20 PM   #4
simon5 is offline simon5  Canada
This foam will simulate a bit the aperiodic box. I guess it will be closer to a ported box with the foam in the port.
http://www.partsexpress.com/pe/pshow...=296-546&DID=7
DIYaudio for President !
Port close to the wall--effect on tuning? diesel_88 Multi-Way 3 26th April 2008 10:57 PM
PPI tuned off! skooter Car Audio 4 24th November 2007 03:08 PM
Foam, thicker foam or Open Cell qguy Subwoofers 4 11th March 2007 07:06 PM
Speaker damping: Foam or expanding foam akunec Multi-Way 2 16th September 2005 06:26 PM
Slot loading versus tuned port coolkhoa Multi-Way 5 20th January 2004 09:18 PM
Page generated in 0.08461 seconds (70.43% PHP - 29.57% MySQL) with 10 queries
