Old 21st September 2005, 04:58 AM   #11
AJinFLA is offline AJinFLA  United States
Banned
Vifa XT-19 http://www.d-s-t.com/link/vifa/data/XT19TD00-04a.htm
Seas W22EX http://www.seas.no/PDF%20data%20exce...EX001E0022.pdf
Peerless XLS12 http://www.d-s-t.com/link/peerless/data/830500.htm
AJ
Old 22nd September 2005, 06:28 AM   #12
Dear AJinFLA,
Thank you,
M
Old 22nd September 2005, 10:04 AM   #13
icebear is offline icebear  Norway
Default V-split dipole
Hi
I have been fooling around with dipole woofers for some time, and tested a lot of prototypes. H, W, ripole, linkwitzbox ++
The last one I tried is a Vertical split system. (Norwegian Pat nr. 166989)
It combines the Karlson box and Vertkal split teory. Add a plate in front of the driver, and it will gain a pressure. The pressure will hold better than just the motion from the driver. You will also gain a correct impulseresponse.
I must say that the result is better than without the split (only W-baffle), and i had to turn down the 6 dB compensation. I'm now running witouth compensation, and it working fine ( And I'm just running one at the time )
rgds
Bjorn
Old 22nd September 2005, 11:39 AM   #14
john k...'s Avatar
(JPK) You migh also want to look at the first 3 articles in my Tech section, http://www.musicanddesign.com/tech.html The U-frame atricle looks at both U and H frame woofer and addresses the need for damping in the U-frame. The crossover article looks at how the radiation pattern varies through the crossover region when different types of sources are corssover over, i.e, monopole yo cardioid, dipole to monopole, etc. The room gain article discusses room gain for dipole, monopoles and cardioids.
John k.... Music and Design NaO Dipole Loudspeakers. "We have no right to assume that any physical laws exist, or if they have existed up to now, that will continue to exist in a similar manner in the future." Max Planck
Old 22nd September 2005, 01:57 PM   #15
Banned
I didn't forget you John, your site was the first link in my original reply
But what to make of the pic above your post? The Karlsonpole? Resonance anyone?
At least I like his wood working skill and craftsmanship. That looks a lot like mine.
AJ
Old 22nd September 2005, 02:00 PM   #16
HEY!!!
It's just a prototype
(I hope)
b
Old 22nd September 2005, 03:01 PM   #17
Banned
My finished ones look just like that
cheers,
AJ
Old 22nd September 2005, 11:19 PM   #18
Default Vertical Split Theory
Icebear,
Have you read that patent? (is it Forsman's?)
If so, could you please give us an idea of what it's about?
Thanks,
Pete McK
Old 22nd September 2005, 11:38 PM   #19
freddi is offline freddi  United States
freddi's Avatar
hey icebear - way cool - does your proto's wings flex much? - I run Karlson at 400 watts nearfield and wings can sing - haha
hows your dipole Karlson sound on drums, strign bass and pipe organ stuff? - how about techno/hiphop?
funny thing running wideband Karlson - small changes in flare,gap nd initial slot area produce subjectively large changes in timbre (and sometimes subjective extension) besides altering Z curve. perhaps choking down area in the tight portion of slot does some change in direct - indirect energy (from top half of chamber) that won't show up on mic - and maybe wave release rate. these variable3s give a lotta leeway on adjusting tonality.
did you look at Reams Karlson-hypex patent?
Robert W. Reams US 4196790 filed 1978 “Acoustic Transducer having Multiple Frequency Resonance”
http://home.earthlink.net/~buddhaboy2/RM/H.jpg
here's my little 18" k-toy
http://home.earthlink.net/~buddhaboy2/13.jpg
Old 24th September 2005, 12:05 AM   #20
freddi's Avatar
Hi Bjorn - forgot to ask- are running both drivers? - what's parameter and K-dipole enclosure details?
Freddy
H frame vs W frame dipole woofers rick57 Multi-Way 18 8th October 2011 05:58 PM
W-frame Dipole Construction Q weinstro Multi-Way 9 20th August 2007 04:31 PM
Dipole H/W frame using 15" drivers arc2v Subwoofers 16 17th August 2007 11:39 PM
how to calculate resonance in dipole H-frame? thadman Subwoofers 4 17th April 2007 09:10 PM
W-Frame or H-Frame dipoles? performace issues? JinMTVT Subwoofers 34 5th October 2006 05:44 PM
Page generated in 0.11251 seconds (79.29% PHP - 20.71% MySQL) with 10 queries
