Wallin II / SW impedance calib problem
Old 19th September 2005, 05:31 AM   #1
ultrachrome is offline ultrachrome  United States
Default Wallin II / SW impedance calib problem
I'm having a heck of time peforming the impedance calibration with my jig.
My impedance curves for my drivers never dip below 12 ohms for what should be 7-8 ohm drivers.
My jig measured out correctly after I built it but I notice that when I have J2 and J3 connected to my sound card (M-Audio Transit USB) and set the jig to 16 or 4 ohm calibration mode that BP3-BP4 measure 31 and 8 ohm, respectively. Is that normal?
My other problem is that the calibration process says that I appear to have an open connection.
I've tried connecting it to the laptop's internal sound card and have tried different cables but I still keep getting the same error message.
Any ideas?
Old 19th September 2005, 08:26 AM   #2
noodle_snacks is offline noodle_snacks  Australia
Send a message via MSN to noodle_snacks
Have you gone through the process of setting the levels using loop record mode and a sine wave? I found the peaks of the waveform clipping were giving me some trouble in impedance measurements.
Old 19th September 2005, 10:15 AM   #3
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Default Re: Wallin II / SW impedance calib problem
That's not normal. I suggest going through the jig electrical checkout first.
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 19th September 2005, 03:56 PM   #4
Looks like it's a problem with my laptop. In the IMPCAL16 mode, the BP3-BP4 resistance measures 32R when plugged into the Transit and 64 when plugged into the laptop's line in.
Did the Wallin checkout a second time and found no problem.
Took the jig downstairs to my desktop line in and IMPCAL16 meausures 16R just like it's supposed to.
Crap. Now I need to drag my desktop upstairs. Girlfriend is not going to like that.
Old 19th September 2005, 03:59 PM   #5
Default ****
Wow, that auto-censor is touchy. If you make that word plural, it's a dice game.
Old 20th September 2005, 11:04 AM   #6
wintermute is online now wintermute  Australia
just another
wintermute's Avatar
Did you try measuring again after doing the first calibration? sometimes if the calibration is out it will take a few goes to get a proper reading.
The other thing that might help is working out the impedance of your laptops sound card, and put that in instead of the default.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 20th September 2005, 03:18 PM   #7
I tried using my desktop machine with its cheesy built-in Realtek AC97 sound card and it calibrates fine and I now have accurate looking impedance plots of my tweeter and midrange.
Wallin II / SW impedance calib problemHide this!Advertise here!
Wallin jig, sound card and connection problem JacquesK Multi-Way 5 19th May 2008 09:48 PM
Switch impedance issues in Wallin 2 Jig Dave Bullet Multi-Way 9 28th May 2007 10:13 PM
problem with Wallin preamp 2 wintermute Chip Amps 10 18th January 2005 07:37 PM
OT impedance problem m0rg Tubes / Valves 2 9th July 2004 04:58 AM
Wallin Jig 1 for Speaker Workshop: Wiring Problem?! Rarkov Multi-Way 1 12th September 2002 08:18 PM
Copyright ©1999-2017 diyAudio
