Old 19th September 2005, 06:22 AM   #1
trusound's Avatar
Send a message via AIM to trusound
Default my first time open bafles
Well I thought I'd give it a whirl...still have acouple more days left on the first one to make sure everything will work out as planned...basically the setup will be :
seas Seas T25CF002-06 Millenniums
Seas W22Eoo2
Seas W26
The bottom portion"triangle" will be wrapped in a veneer with a front firing Seas W26
the top portion will be smoothed and painted a candy burgandy with a veneer inlay...
I'll post more pics when I get furtherClick the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
Old 19th September 2005, 07:14 AM   #2
12 Cents's Avatar
Default I like!
Will you call them Snake Charmer ? Will they be active XO?
Old 19th September 2005, 02:48 PM   #3
trusound's Avatar
I am hoping to mate them with a DEQX.... it still has a ton more left as far as finishing...
Old 19th September 2005, 03:05 PM   #4
ShinOBIWAN's Avatar
In the third pic down, just what are you doing with the hand that isn't holding the baffle?!?
I'm surprised you've gone the W22 for mid range though, I would have maybe gone for the W18. From my measurements the cone break up starts at 2.7Khz with a broad peak at 3.5Khz. Where are you crossing to the treble and what rolloff?
Nice to see someone use the Crescendo treble BTW.
EDIT: My bad, your using the millenium and not the crescendo.
Old 19th September 2005, 03:28 PM   #5
Davey is offline Davey  United States
Interesting.
I don't think I'd be concerned about the high end of the W22. Rather the low end. That's an awfully small baffle with a very good front/back short circuit path. You're going to have to equalize the heck out of that thing to go fairly low in frequency. Maybe you're planning on running the W26 driver fairly high, say 300-400 Hz?
It's also very unclear what the polar response will look like.
Davey.
Old 19th September 2005, 06:07 PM   #6
AJinFLA is offline AJinFLA  United States
Banned
Davey,
I thought the same thing. Which then begs the question, Tru, you're going OB above the modal region and closed in ?
Thats interesting, although I've seen it on Troels(sp) site before.
Love your woodwork, wish I was half that good .
cheers,
AJ
Old 19th September 2005, 06:38 PM   #7
Svante is offline Svante  Sweden
Svante's Avatar
I'd be a bit concerned about the baffle step for the tweeter. The distance to the edge is almost identical for more than half of the turn. That will lead to ripple in the response, like in the simulation below. The simulation is a guess with the baffle measures estimated from the pictures.
But I agree with the others on the cool look of the project!
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 19th September 2005, 11:07 PM   #8
trusound's Avatar
Thanks guys for the input...this is my first wack at it...and I have a few changes for the second set...basically this first one it to see if I can get the materials to do what I want...then the next set will be to fine tune and problems with the shape of the baffle.. I am hoping to start working with acouple of local interior design shops and start making loudpseakers that can be custom made and designed for the WAF and still give incredible performance per house or buisness etc... My other plan is to build unconventional peice see the rough drawingClick the image to open in full size. Click the image to open in full size.
Old 20th September 2005, 08:22 AM   #9
Svante's Avatar
I think you'd be doing the same mistake again if you built those. The distance between the tweeter dome and the edge of the baffle should vary over the turn. The way you have drawn it, with a circular circumference around the tweeter (and woofer) will yield a strong ripple in the baffle step. At least, try The Edge in my signature, to simulate the baffle step. You will find that an ordinary rectangular baffle is pretty good. A friend of mine got very aware of this problem as he built these:
Old 22nd September 2005, 06:22 AM   #10
trusound's Avatar
more pics of the progress of my baffles...
The back is finished for the most part and tommorrow it's off to the front...
http://pg.photos.yahoo.com/ph/randy_...75.jpg&.src=ph
http://pg.photos.yahoo.com/ph/randy_...d4.jpg&.src=ph
http://pg.photos.yahoo.com/ph/randy_...c2.jpg&.src=ph
http://pg.photos.yahoo.com/ph/randy_...ac.jpg&.src=ph
these are pics of my budy rick holding the drivers in place
http://pg.photos.yahoo.com/ph/randy_...dd.jpg&.src=ph
http://pg.photos.yahoo.com/ph/randy_...0f.jpg&.src=ph
http://pg.photos.yahoo.com/ph/randy_...5f.jpg&.src=ph
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
Time To Try Open Baffle Mutley666 Multi-Way 40 1st March 2006 08:50 AM
Time-Aligned Open Baffle Line Arrays.... chops Multi-Way 36 25th January 2006 12:15 PM
First time caller, long time listener... smallangryboy Introductions 15 19th March 2005 08:10 PM
Open baffle drivers configuration: time to ask the experts Peter Daniel Multi-Way 28 31st October 2002 05:54 PM
Page generated in 0.12484 seconds (75.37% PHP - 24.63% MySQL) with 10 queries
