...I recently constructed a car audio system out of DIY parts from Madisound. I'm using a 8" Silver Flute woofer, and right above that a 4" Vifa midrange driver in the doors of my car, and on the dash near the A pillars, the Vifa ring radiator tweeters. Ive built plenty of woofer enclosures but I dont have much experience in terms of midrange drivers.
Anyway, the Vifa 4" midrange I'm having a problem with, I have a sharp peak in the response at 1K. It makes the system sound VERY shouty and is fatiguing to listen to. Based my on my RTA, it is a 7-10 dB peak. I used my electronic 1/3 octave graphic EQ with 1000 Hz set at -10 to offset the problem. I'm wondering if anything can be done non-electronically to get to the route of the problem. I think the main thing is about 1/3 of the driver is covered by the door skin of the car and then alot of it is reflecting off of the lower dash, so that is creating a nasty peak. I'm thinking to stuff as much sound absorbing material behind the part of the door skin that is being covered. What about behind the midrange driver? Right now I have nothing, it just radiates into the door. Here is the anechoic response from the MFG and a pic of the driver.
| FS: Large inductors, Large Ports, and Leaky Holes | luvdunhill | Swap Meet | 10 | 6th March 2009 03:01 PM |
| 1khz square wave | ak_47_boy | Digital Source | 3 | 14th August 2008 04:18 PM |
| 200V peak to peak @25MHz | ketan | Parts | 1 | 8th June 2008 03:21 AM |
| Pre Outs and peak-to-peak ? | CheekyMonkeyVZi | Car Audio | 7 | 12th December 2006 08:30 AM |
| Ultimate DAC - Upsampling PCM 44.1Khz to DSD | proengin | Digital Source | 4 | 13th March 2006 11:02 AM |
| Page generated in 0.99694 seconds (5.40% PHP - 94.60% MySQL) with 10 queries |
