What happen to my sub! - Page 2 - diyAudio
Old 30th September 2002, 08:14 PM   #11
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
If the wax left some oil deposit on the sub, you can now try to clean it with something that removes that oil. Use a cardboard first to experimnt. You have nothing to loose anyway.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 30th September 2002, 11:56 PM   #12
Send a message via AIM to Jared
maybe you could spray it with alcohol in order to try to disolve some of th oils and evaporate it away?
The problem you are going to run inot is that citrus oils tend to disolve adhesives. A lot of furniture waxes have citrus in them. Personally I would attempt to heat it first. Maybe your oven has a warm setting you could leave the driver in the oven with it set to warm and the top slightly open and let it dry that way for a few hours. I would not try the direct sunlight, sunlight does all sorts of bad things to materials. Make sure to have the driver facing stright up in order to hopefully not casue voice coil alignment issues.
Old 30th September 2002, 11:59 PM   #13
haldor is offline haldor  United States
After you get the oil out, you might try painting the cone with clear lacquer to stiffen it up.
Phil
Old 1st October 2002, 12:01 AM   #14
And be careful not to heat the rubber too much or it might loose its properties.
www.audiosector.com
Old 1st October 2002, 12:29 AM   #15
diyAudio Moderator Emeritus
roddyama's Avatar
The ultra-violet from the sun is pretty bad for rubber, foam or otherwise. If you decide to dry it in the sun, cover the surrounds to protect them from the rays.
Also, you have to be very careful with solvents because you’ll loosen the glue holding the surrounds to the cone. You might want to check that you haven’t already done this with the original cleaning attempt.
Good Luck.
Rodd Yamas***a
Old 1st October 2002, 05:46 PM   #16
Thanks for your help,
I haven't get it fix but it is almost.
1, I put it under the hot sun with newspaper cover on the sub's rubber place. Termometer beside the sub.
2, I let the sub under the sun about 7 hours, termometer went all the way up, the max number only got 50'C and it is above it.
3, After trying to dry the oil, nothing happen, still the same, still got cracking sound.
4, I found out the cone was ofter then before. Then I search for somthing that can make the cone hard.
5, Found 1, maybe is the hope in front of my eyes.
6, And it is Starch, ahuh, starch that use on clothes.
7, first sub for experiment, spray on it, dry, spary, dry, spray again, dry. the sub cone get harder.
8, wire attach, then switch on for a test. The sound got no cracking at low volume, high volume start to crack, not sure is it cracking sound or not cause without box the sub shake like hell..
9, Spary and dry it again, then spray it, let it dry self......
10, still in process give my answer soon.
Old 1st October 2002, 08:08 PM   #17
Mikka.
Time for a reality check.
You should consider that driver an experiment now and give up hope that it's going to ever be like new again.
No matter what you do it's never going to be the same as it was.
Just replace it and learn from the experience.
There is only so much chemical abuse the cone is going to absorb before it just gives up and turns to dust or self-ignites due to the numerous compounds you've applied to it now.
And we won't even talk about the surround...
Old 2nd October 2002, 05:26 PM   #18
don't say it like that, just got it fixed.
The sub's cone turn harder then ever, and the woofer is too small to blow, make some noise. But the bass is more stable and powerful. It can shake the floor in low volume.
Maybe from my experiment can help others who also use wax or somthing that can soften the sub's cone.
Old 2nd October 2002, 05:33 PM   #19
FrankDIY's Avatar
That's bad...I was about to suggest to make a candle holder with your sub
Imagination is more important than knowledge. knowledge is limited, imagination encircles the world. Albert Einstein
FrankDIY's Audio Corner
Old 2nd October 2002, 06:07 PM   #20
UrSv is offline UrSv  Sweden
UrSv's Avatar
And to be totally honest, you are the first one I hear of that cleaned his woofer cone that way...
/UrSv
What would happen with a 45V transformer??? camshaft Chip Amps 3 27th February 2007 07:04 PM
what would happen if... aletheian Tubes / Valves 8 14th September 2005 04:34 AM
What happen with this transistor? lumanauw Solid State 22 19th February 2005 01:41 PM
Is it normal for this to happen? xstephanx Subwoofers 16 14th January 2005 03:26 AM
Copyright ©1999-2017 diyAudio
