My DCX2496 is home now . I have opened it and admired its cheesy copy-cat looks and then shuddered at the War and Peace sized hand book.
Why do i have to learn Gaussian Physics just to set the damn thing up Oh well . I better drink to a weekend lost learning how to use this thing. I can only guess how much worse it will be daisy chaining the DEQ2496 to it next week
Persistence is better then intelligence. Unless persistence kills you. |
#2 |
I am still jealous though!
#3 | |
I'm running all digital in my audio chain : CD -> SRC2496 -> DEQ2496 -> DCX2496 -> amps... Sounds much better than any analog solution I tried... BTW: Just remember you want to send hot line level signals to the DCX otherwise the noise floor will be audible... especially if you have high sensitivity drivers Good luck and keep us updated, --Chris |
#4 |
I'm writing a simple guide in Microsoft Word using screenshots.
If you have troubles still, send me email and I can give you the doc when it's done. |
#5 |
Hi
I would be interested in that document. Thanks Jozua |
#6 |
Id like to see that doc too.
#7 |
Ohhhhhhhhhhhh WoW ! ! !
I know this the budget model but ^^ see first line I just hung a microphone where my head would normally be and hit the auto setup thingy (after i set my crossover slopes ) and viola' Now if only i can figure out how to make it stop 'singing'when there is no signal. thats really annoying
#8 | |
See my first post mike, You need to increase the signal to the DCX as high as possible and attenuate the analog signals after the DCX before the amplifiers. The DCX has a slght hiss at a fixed level regardless of input/output levels. Its barely audible if you drive 70% or higher analog levels. If you have gain controls on your amplifiers just turn down the amplifier gains and increase your preamp. If not, you can add fixed 24db attenuators on the outputs, or even pots for volume control. --Chris |
| Zen#9 is arrived ! | gionag | Pass Labs | 17 | 6th October 2008 07:58 PM |
| New toy has arrived! | I_Forgot | Digital Source | 0 | 1st February 2008 01:57 AM |
| Just arrived | marcograziano | Introductions | 1 | 16th December 2004 12:52 PM |
| New parts arrived & will foloow with kit, !!!!S1 12pcs arrived from Holland!!!! | tube-lover | Swap Meet | 1 | 4th September 2004 12:29 AM |
| ZV4 has arrived. | Nelson Pass | Pass Labs | 74 | 21st September 2002 09:56 PM |
| Page generated in 0.10966 seconds (77.65% PHP - 22.35% MySQL) with 10 queries |
