"Mmmmm......Beeeer" |
#2 |
WTF
Xpeak of ±30mm ???? but 9mm xmax? |
#3 |
Banned
That's far from unusual. Look at the Xmax vs Xmech of most pro drivers http://www.partsexpress.com/pdf/290-580.pdf
cheers AJ |
#4 | |
Stange because usual notation would be Xlin 9mm and Xmax 30mm but I guess the guy doesn't know that The variance between the two also suggests to me that the cone travel isn't very linear at all and/or the motor isn't upto much. BTW xmax is +/-30mm for 6.5"!!! Thats nearly as good as the XXX or tumult! |
#5 |
#6 |
#7 | |
#8 |
cant see whats going on under the bottom of the driver - is the spider suspended and the gap is to allow movement
does something but into the bottom - a pole piece maybe they're cool thats for sure |
#9 |
Banned
#10 |
Never seen those either. By the looks of the cone and front mounting plate they come from the same factory.
| Any info on old Seas drivers? | Brisso57 | Full Range | 14 | 30th January 2011 03:47 PM |
| Any info on Goto drivers? | 454Casull | Multi-Way | 30 | 30th June 2010 10:58 PM |
| New eton drivers... need info. | Jed | Multi-Way | 11 | 20th May 2007 07:42 PM |
| Need info on these JBL Drivers | Maxxarcade | Multi-Way | 2 | 28th May 2005 05:42 PM |
| HELP please Info on these drivers | gar1 | Full Range | 0 | 14th December 2004 07:03 PM |
| Page generated in 0.11147 seconds (79.81% PHP - 20.19% MySQL) with 11 queries |
