Help to chose XO frequency - diyAudio
Old 12th September 2005, 08:55 PM   #1
potepuh is offline potepuh  Slovenia
Default Help to chose XO frequency
Hy DIY folk. I need some help-advice.
I am planing to built the Vifa Premium center loudspeaker with bass unit Vifa PLW14/232/8 (two units) and for the tweter Vifa XT300 or XT25. My plan is to go active. So i would like to know what is the best frequency to cross this drivers. (I do not have any practise with designing crossovers) I will use the L-R 24dB active crossover.
And what is the best crossover frequency for scan speak 18S/8545 and D2905/9500. Maybe something about 3kHz. Againn L-R 24dB active crossover. This two units are plant to be used in a future watt/pupy clone as satelites.
Any advice will be usefull.
Old 13th September 2005, 12:58 AM   #2
mike.e is offline mike.e  New Zealand
mike.e's Avatar
Send a message via ICQ to mike.e Send a message via MSN to mike.e
You must avoid the tweeter resonance.
You must crossover below the point at which the midrange starts beaming - see link.
You must compromise between all of these,and listen to what sounds best.
Theres much more but theres a start.
Then you can start thinking about phase in the crossover region and if its important.
http://www.linkwitzlab.com/x-sb80-3wy.htm
http://sound.westhost.com
which design should I chose? kalinowski Full Range 8 13th June 2008 07:54 PM
Which SPICE to chose ? nicolas888 Everything Else 1 12th September 2006 09:25 PM
How to chose the right choke Mikael Abdellah Tubes / Valves 7 2nd August 2006 08:47 AM
Phono stage kit? need help to chose - TY rmihai Analogue Source 7 6th October 2005 10:41 PM
wich to chose JBL Tubes / Valves 0 12th January 2002 01:51 AM
Copyright 1999-2017 diyAudio
