Old 12th September 2005, 08:02 PM   #1
akunec is offline akunec  Canada
Default Lambda TD12s Closed Box / Bass Reflex Design
I'm going to build a pair of speakers using:
Lambda TD12S 35-350hz
PHL 1120s 350-2800hz
Morel Supreme 110 2800-20khz
Using 3d cad, my maximum box volume for the Lambdas that I can withstand is 69liters net (each).
Using that volume I have come up with a design as follows:
It will consist of 2 ports 10.2cm (4") by 21cm. With both of them opened it will have a 45hz tuning (~2dB bump). This setup would be suitable for when I have parties at my place. With one port closed, it will have a tuning of 33hz. This makes the response very flat, and seems to be more less, ideal for me, given that volume.
With both ports closed, it will act as a sealed box with a Q of .54.
Any thoughts/comments on this setup?
Alex
Old 12th September 2005, 08:18 PM   #2
Looks good.
Will you protoype with active or jump to passive using generic crossover points?
Old 12th September 2005, 08:41 PM   #3
I'll probably get a DCX 2496 to prototype with.
I'll be powering the speakers with a 6 ch gainclone
The Lambdas each have a bridged LM3886 to power them.
The Morels have one 3875 and the PHLs have a 3886.
Old 12th September 2005, 08:57 PM   #4
JohnL is offline JohnL  United States
JohnL's Avatar
I have tried TD12S in a 90L box with 2 4" ports (I think the ports were closer to 12") and they sounded great, but the boxes were just too huge for the living room. I went to a 55L sealed box and they sound great, if not a bit bass shy.
John
Old 12th September 2005, 09:18 PM   #5
I assume you are using Dual PHL's since you want 350hz out of them?
BTW there's at least a 2 mth waiting period on lambdas so I hope you have the 12
Old 13th September 2005, 12:21 AM   #6
No, I'm using just a single PHL 1120. If it starts to get a little edgy, I'll shift up the xover freq. I realize Phlaudio recommends a 400hz xover, but I think this is for prosound applications.
I already have all the drivers i need.
Old 13th September 2005, 12:22 AM   #7
to keep SQ very very high.... I cross mine at 450hz currently.... and I have a pair per side
Old 13th September 2005, 02:44 AM   #8
Your plan sounds good. If the bass sounds anemic, get a bigger power
amp for the woofers.
Perhaps add a monster subwoofer for HT duty if these speakers are
part of such a setup.
FS: 3 Lambda TD12S drivers doug20 Swap Meet 5 3rd May 2009 07:24 PM
tiny bass reflex design? xdissent Full Range 7 13th May 2008 09:57 PM
Lambda TD12s T-Line? akunec Multi-Way 5 11th July 2005 04:29 PM
FS: Lambda Acoustics TD12S (faraday) woofers pkpickard Swap Meet 5 18th December 2004 09:56 PM
Bass Reflex design using MJK software teodorom Multi-Way 2 23rd May 2004 05:16 PM
Page generated in 0.09546 seconds (78.09% PHP - 21.91% MySQL) with 10 queries
