Newbie questions -
I've decided to rebuild an old pair of donated DCM TF 1000's. One of the 3" drivers has a gouge in it, but I don't know what to replace it with. On the back, it says: HDM100A 8 Ohm 405 1460 Also, there are two layers of grill cloth. The inner one has some sort of black foam material on its inside, but it is deteriorating badly. What can I use to replace it with? Any other rebuilding tips would be greatly appreciated. Thanks in advance, Dan |
#2 |
re. the 3" driver replacement - why not contact DCM or an authorized service location for the recommended driver?
regarding the cloth wrap, DCM says it's integral to the design of the speaker's acoustics and specially designed for the speaker. depending on how you're gonna be using the speakers, you might wanna have an authorized service center fix 'em. good luck to ya! k. |
| DCM Time Window rebuild | danclarkwcp | Multi-Way | 82 | Today 02:04 AM |
| H frame vs W frame dipole woofers | rick57 | Multi-Way | 18 | 8th October 2011 04:58 PM |
| DCM Time frame TF400 woofers | sandstorm33 | Multi-Way | 0 | 20th March 2007 06:55 PM |
| W-Frame or H-Frame dipoles? performace issues? | JinMTVT | Subwoofers | 34 | 5th October 2006 04:44 PM |
| re-use DCM time frame drivers | quiet | Multi-Way | 3 | 27th February 2006 03:11 AM |
| Page generated in 0.07632 seconds (73.42% PHP - 26.58% MySQL) with 10 queries |
