Ok i have to make some changes. I love what i built so far even though it is ugly as sin. Now i want to rebuild the tops but with a better high frequency transducer and another morel MW266 which is sweet beyond belief in a sealed cabinet.
As it stands now i have the big Hi-Vi RT8 ribbon/planar tweeter a single morel mid and dual 10 inch bass per side. i want to have 2 x morel - 2 x 10 and a less finecky tweeter. What kind of suggestions do you all have. Ceramic aluminum fabric ? I am all active so i dont need to worry about x-over anomallys, unless they have to crossver above 3k then that could be a bit of a problem. Michael
Persistence is better then intelligence. Unless persistence kills you. |
#2 | |
Banned
You should cross it higher, and to do that you must also choose a smaller driver for the midband, one that has good response and dispersion charateristics up to higher frequencies than the Morel MW266 you are using. |
#3 |
i have a couple seas Excel Millennium if your interested in going to a quality dome.i found it alittle to laid back so i replaced it with the lcy110 in my seas odin kit
#4 | |
The mid is fine and runs right up past 4k before i start noticing a honk and squeeze sound. The Hi-Vi has good dispersion horizontally. I knew pinpoint imaging was not going to be achieved with something that large. So i am going to rebuild the top cabinets with 2 Morels. I want more mid bass smack . Also the hi vi does not really go past 16 k on the RTA. large drop off above there. So i am leaning towards ring radiators or mabey those externally mounted tweeters from Morel or LCY . The Hi-Vi cross over is 1800 Hz and has been like that with a few tweaks since i got the cross over and 3 amps. I really like the inverted ceramic dome Fplots on some of the websites that sell speakers with them.
#5 | |
Banned
You will not be able to cross them low, they will distort, as most domes (except the best ones) do. And you will probably not have such a fast and clean midband/treble as the ribbon. Here's something for you to think about: how about keeping the Hi-Vi ribbons and try the Morels on top, crossed very high as super-tweeters? |
#6 |
hmmm didnt think of doing that . Get another pair of the 266 and go Dipole mid-bass with a super tweeter, since i dont give a whit what it looks like presently.
#7 |
Anyone got a pair of MW266 they want to part with ? So i dont nessicarily have to buy new ?
| Page generated in 0.13741 seconds (60.06% PHP - 39.94% MySQL) with 9 queries |
