Old 8th September 2005, 06:10 AM   #1
Jay is offline Jay  Indonesia
Default Speaker Workshop: tweeter's built-in filter
This is from Speaker Workshop:
"Tweeters are really just drivers with built-in enclosures. They come in 2nd order and 4th order (most often) depending on whether or not they are a vented design. A 2nd order tweeter melded with the right 2nd order crossover can produce a good 4th order acoustic crossover. When using a 4th order tweeter use a higher order crossover to improve power handling."
How do you know that they are 4th order or 2nd order tweeter? And how can this relate to a vented (box)? Anyone care to explain? I'm also confused with the last statement
Old 8th September 2005, 04:03 PM   #2
ShinOBIWAN's Avatar
The rate of the natural acoustic rolloff of the tweeter is 2nd or 4th order, determined by the mechanical properties of the tweeter.
Then when you apply a 2nd order XO you get 4th order etc.
Virtually all tweeters have no rear wave so loading in a cabinet makes no difference. Baffle step does make differences though.
Old 8th September 2005, 07:35 PM   #3
Default I wouldn't do it
Using the tweeter rolloff is not the optimal way to use them, because tweeters have limited excursion and you would run into distortion fairly quickly if you cross them over low enough to use the rolloff as a part of the crossover.
Old 9th September 2005, 01:37 AM   #4
Stocker is offline Stocker  United States
Which is part of the explanation of the last sentence, re: the power handling.
Jesus loves you.
Old 9th September 2005, 06:07 AM   #5
Oh, thank you all. I see it now...
So the rate of the order can simply be seen from the relative steepness of the natural roll-off graph/pattern. Whatever causes that! Initially I thought the 'vented' design has something to do with tweeter chambers, because what has it to do with speaker enclosure?
So the statement is referring to crossing the tweeter at it's natural roll-off to create higher order natural/accoustic filter, and because it is close to Fs (especially for 4th order natural roll-off?????) then high order filter is mandatory to improve power handling.
(I did that intentionally only with woofer, because it doesn't have the Fs issue)
DSP_Geek, some tweeters like Dynaudio D21 like to be crossed near Fs. Only for low SPL and that's the headache indeed.
Old 9th September 2005, 11:55 PM   #6
Speakerholic
Cal Weldon's Avatar
I've not heard of that before.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 10th September 2005, 02:00 AM   #7
Mmm. Note that crossing a driver near Fs, unless the impedance peak is compensated with a conjugate network, means the response around there might not be what you expect. Perhaps that non-flatness compensated for a failing elsewhere in the system, maybe the woofer had a dip at that point.
I'm not saying you're wrong, just that I don't know the variables about the time you tried it. I still prefer to cross my tweeters at least an octave above Fs.
Cone mids, on the other hand, are entirely fair game for this approach.
Francois.
Old 10th September 2005, 02:51 AM   #8
rcw is offline rcw  Australia
Acoustically a closed back driver is a second order high pass filter, and if it has a q=.707, cascading it with a Butterworth filter of the same frequency gives an exact L-R type chracteristic. Crossing it over at any other frequency will not give this due to residual phase shift, unless a Linkwitz transform "bi-quad" filter is used.
There also exist "quasi L-R" crossovers that allow crossovers in the f3-2f3 region of the tweeter, whilst still retaining the in phase through the crossover region property of the L-R.
Old 10th September 2005, 04:11 PM   #9
Actually I didn't mean that crossing D21 near Fs is good. What I mean is that in many tweeters, they tend to sound better when crossed low (assumming that the resonance should have been taken care of). This makes tweeters to sound open. And crossing low means crossing near Fs, doesn't it? Besides, D21 has Fs at 1K3! (This gives subjective truth, since not many woofers can have good midrange above 3K)
XT25 is the best exception. Initially I thought the Quality/Price will be lower to cross it at high Fc, actually I found the opposite tends to be true. But I still have some doubt about the 'true' x-over point of XT25 crossover. If you 'cross' XT25 and another tweeter at the same frequency and order, the XT25 will outputs more vocal (and is very sweet , but not my cup of tea ) as if it has shallower roll-off, and it seems it still takes the benefit of low Fs.
Old 10th September 2005, 04:21 PM   #10
Francois.
Of-course I can be wrong. But I tried it in many occasions. I used to have inductors in almost every values. I tried many crossovers for every pairs of drivers.
With Fs at 1K3, what F will you cross the tweeter at? I have had plenty of headaches crossing woofers at 3K
Speaker Workshop, help please Grahamt Multi-Way 5 10th March 2005 12:48 PM
Speaker Workshop do all this? rick57 Multi-Way 8 20th November 2004 03:11 PM
A little Speaker Workshop help kneadle Multi-Way 18 25th October 2004 11:12 PM
Which mic for speaker workshop? azira Multi-Way 2 12th February 2004 06:12 PM
Speaker workshop Ilianh Multi-Way 2 10th January 2003 10:11 PM
Page generated in 0.12748 seconds (78.91% PHP - 21.09% MySQL) with 10 queries
