#2 |
These are facsimile,not original Sonus Faber!!!!
woofer is different tweeter is different crossover is different cabinet is perfect ( too much perfect, maybe the man has modified/ "upgradated" a pair of original Minima SF, in his attempt) The minima project is about 20 years old. regards, |
#3 |
well....
do you think are they worth build to? Is there any better project for the same $ ? Maybe using SS revelatros..? Regards. |
#4 |
diyAudio Chief Moderator
'Cloning' in DIY is a loose term.
I would go for a Zaph design: http://www.zaphaudio.com/audio-speaker12.html |
#5 |
e-can, (sorry for my english)
I don't understand your position. Have you listened the SF Minima or not? In the "hall of fame" of hystorical minimonitors Minima is a true little jewel. Some people prefer the LS3/5A, others the ENSAMBLE PA1 , others the Spica T-50 or T60. Do you know these speakers? In a previous post I specified you all the story. Seas 11 FGX = CA 11 RCY= H149 ( Madisound 43 USD each) For the tw, if you have not the D28-D28/2, the MDT 30/32 is acceptable in the simulator, The SEAS TFDC 27 seems perfect with the original filter. But this is a simulation, caution is required . Today Minima is out of production. In Italy one pair of Minima used is about 450 euro. I haven't others advises to you. regards P.S. :In a Italian Audio Review interview with SF's Patron little time ago , he declared his reference speaker was Minima again ( not Guarnieri,Cremona,Amati,etc) !!!!! |
#6 |
->inertial
Hi. I've just brought the speakers (excells and morels). I was wondering why there is no info about them. I've not listened any of mentioned monitor....Now I see why there is no info about SF minima...out of production...but I was wondering if there is any better project at the same $...I could buy the SS revelators,but didn't.....troels gravsen wrote that minimas almost beats his LS3/5A...so I decided to build them...so from your point of view it's a good choice to build minima's ? I don't want any alu speakers...I prefer 'soft' sound..don't want to listen metalic sound....excell is much better especially paper one's... Regards. |
#7 |
e-can,
the excel 4" is a bit different from 4" standard. No ideal situation. But , you have the raw drivers... so try a prototipe and listen it! I can't talking about things I haven't listened My opinion is irrilevant. If you can try all the 3 x-overs and judge yourself........ good luck ! Cheers |
| Sonus Faber stradivari | B4 | Multi-Way | 6 | 2nd August 2008 02:31 PM |
| Which midrange used in Sonus Faber | rinx | Multi-Way | 27 | 20th June 2008 10:59 PM |
| Sonus faber cremona | jouch | Multi-Way | 10 | 22nd September 2006 06:57 AM |
| Sonus Faber 2 way - Lute... | mot on/off | Multi-Way | 0 | 11th April 2006 05:37 AM |
| Sonus Faber Minima Clone | sianturi | Multi-Way | 2 | 12th August 2002 07:16 AM |
| Page generated in 0.08957 seconds (74.83% PHP - 25.17% MySQL) with 10 queries |
