Old 30th August 2005, 06:14 PM   #1
Send a message via MSN to Sneakypete
Default 8" Woofer Help
Hello all.
Hear is my situation, i came accros some klipsch SP-1 drivers about 5 years ago for free, so i made some boxes for them. The box size is 43" x 10" x 13.5". Tweeter is a compression with a 4 1/2" horn. Midrange is a 6.5 inch driver in its own sealed space measuring 10.5" x 9" x 12.5" internal volume. Woofer is a 8" that is in a 22" x 9" x 12.5", it has a 4" port, and is powered by a plate amp, just like the original klipsch design.
The boxes turned out very good for a first attempt, and the overall sound is good. But the woofers just cant handle near as much volume as the tweeter and mids, the woofers tend to over extend during heavy use or deep bass.
So i would like to know if you would have a recomendation for a good 8" woofer that could handle some more bass?
Klipsch refers to the 8" as a subwoofer, but it looks to be a normal woofer to me, at least compared to my Subwoofer, so maybe a 8" subwoofer?
Very much a audio novice so any help would be appreciated.
Thanks Pete
Old 30th August 2005, 08:12 PM   #2
Speakerholic
Cal Weldon's Avatar
If it already has a plate amp, this one here has worked for me. Good little workhorse. Cheap too.
http://www.tb-speaker.com/detail/1208_03/w8-740c.htm
Cal
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 30th August 2005, 09:05 PM   #3
RJ is offline RJ  United States
Your problem as I read it is - You have high effieciency mids and tweets.
Here's an 8" woofer if put in a Tuba18 can put out 105db at on;ly one watt input.
http://mcm.newark.com/NewarkWebComme...&Ntk=gensearch
http://www.billfitzmaurice.com/plans...products_id/11
This should match your other speakers.
Old 30th August 2005, 10:34 PM   #4
BAM is offline BAM
Send a message via AIM to BAM
Do you know the tuning frequency of the lower portion of the cabinet? The length of that 4" port really makes a difference. If you don't know the length of the 4" port, then it is quite likely that your 8" isn't loaded correctly.
Old 31st August 2005, 12:08 AM   #5
I had looked at that speaker this afternoon, not sure where to buy them?
I was wondering about this speaker, http://www.partsexpress.com/pe/showd...number=264-838 it would fit in my box, but not sure if i have enough volume inside to support it.
I know this may sound stupid, but could i use a car 8" inch woofer? Seems to be alot better selection of actual subwoofers for cars. The problem with them is they are a little on the flashy side.
If car woofer would work how about something like this, http://www.sonicelectronix.com/item_2771.html ?
This speaker calls for a box size of around 1 cubic foot, i have a little more, but might work?
Don't everyone laugh to hard at the car woofer suggestion.
Old 31st August 2005, 12:08 AM   #6
Yes there are plate amps all ready, i have been using these speakers for 5 years. The woofers have gotten worse over time because they have been over extended a few to many times.
Rob the woofers do ok, but this system is used for Home Theater for the most part and the woofers just cant handle those action scenes. When ever a big bass segment of a movie comes up they will fall flat on there face. This system is run by a Marantz SR7000 reciever, and has Klipsch center, rear and seperate sub. The problem is that the 8" woofers in the main speakers will flutter and make the movie sound like crap during heavy bass scenes.
I listen to music on my Kef's, i just want to get this system up to par for the family. Hate having the wife say what is that noise?
Old 31st August 2005, 12:08 AM   #7
The port is 8.5" long, that is all i know.
Old 31st August 2005, 12:17 AM   #8
Speakerholic
Cal Weldon's Avatar
Can't help. My purchases were in Canada. Try googling tang band
[i]I was wondering about this speaker, http://www.partsexpress.com/pe/showd...number=264-838 it would fit in my box[/B]
That's epitrochoidal shape. Isn't yours 8" round?
[i] could i use a car 8" inch woofer? [/B]
yes but most often they are designed to fill a car's cavity, not a room's, I'd stick with the home audio units.
Old 31st August 2005, 12:27 AM   #9
Madmike2's Avatar
definetly sounds like a badly tuned port making the speaker unload
Persistence is better then intelligence. Unless persistence kills you.
Old 31st August 2005, 02:27 AM   #10
Ok, here goes. your speaker is 94 db.
The original specs are here.
# ENCLOSURE TYPE: Sealed (mid/tweeter) / Bass reflex via rear-mounted port (subwoofer)Ported bass
# DRIVE COMPONENTS: Three-way sytem using one 1" (2.54cm) magnetically shielded, neodymium magnet, aluminum dome compression driver tweeter with a 5" (12.7cm) square 90ºx60º Tractrix® Horn, one 5.25" (16.5cm) magnetically shielded, IMG cone midBass driver and one 8" (20.32cm) magnetically shielded, fiber-composite cone subwoofer
# TWEETER: K-101-S 1" (2.54cm) Aluminum dome compression driver
# HIGH FREQUENCY HORN: 5" square 90ºx60º Tractrix® Horn
# HIGH FREQUENCY CROSSOVER: 2300Hz
# MIDRANGE: K-1076-SV 5.25" (13.34cm) IMG cone / cast polymer frame
# MID-FREQUENCY CROSSOVER: 125Hz
# SUBWOOFER: K-1077-SB 8" (20.32cm) Fiber-composite cone / cast polymer frame
# SUBWOOFER AMPLIFIER: Peak output power 225 watts into 4 ohms
# DIMENSIONS (H x W x D): 37" (93.98cm) x 9" (22.86cm) x 14" (35.56cm)
# WEIGHT: 47 lbs. (21.36kg)
# ENCLOSURE MATERIAL: Medium density fiberboard construction (MDF)
# FINISHES: Black ash vinyl veneer
You made new boxes????
Look here for the correct sizes and specs.
http://buypath.shopping.com/xPF-Klipsch_SP_1
It may be that your port is the wrong size and it's unloading at a higher frequency, but then all ported speakers suffer from this.
Scroll down this web site and see a pretty animation on speaker unloading.
http://www.hometheaterhifi.com/volum...ayporting.html
The only way a ported box won't unload is if you build a dual-chambered box;
http://www.diysubwoofers.org/prt/dual_chamber.htm
http://paginas.terra.com.br/educacao...negro/english/
To correctly tune your port we'll need the T/S parameters on that woofer.
If you are looking to replace that woofer you'll have to find one that's 94 db. That probably means a Pro- Sound woofer.
http://www.partsexpress.com/pe/showd...number=294-654
Something similsr to above.
That still won't cure the problem of unloading at low frequency that movies or some music can produce.
I would start all over again and make a correct HT speaker system.
Especially the woofer part.
von schweikert unifield 3, an offshoot from "fullranger with helper woofer" d to the g Multi-Way 15 24th September 2008 10:34 AM
"Box" design and bracing for open baffle woofer array ryoshu Multi-Way 0 17th August 2008 06:07 PM
suspending a small tweeter in front of woofer for "coaxial" effect? bikehorn Multi-Way 3 2nd January 2006 02:04 PM
WTB: Focal & Audiom & Volts 11", 12", 13", 15" woofer gengis Swap Meet 0 17th March 2005 02:29 AM
cheap 6" or 8" woofer to make great bass for a standard cab pick up zuki Subwoofers 12 15th February 2005 07:54 AM
Page generated in 0.13466 seconds (79.40% PHP - 20.60% MySQL) with 11 queries
