hey everybody, I'm in the process of building a 3-way monitor setup for my room. I choose a 3-way because i wanted good midrange that's brought up and detailed and also i can use the datyon 8" woofer that i have. I do not want to use a sub so I figure a 1cuft tune to 35hz should be fine for music. Anyways, here's how I have it hook up right now.
LCY110 HP @ 3khz w/ 12db slope Dayton Reference 6" LP @ 2.5khz w/ 12db slope and HP @ 200hz w/12db Datyon 8" dvc woofer LP @ 160 w/ 6db slope. What do you guys think about this setup. I currently have one side all hooked on the right channel and it sounds really good to me. Im using my Eclipse CA8454 3-way crossover in my room as an active setup, but once i decide on what to do I will built the crossover. Another thing, I have the LCY130 and the Morel MW-167 in my car on a 2-way active setup. the LCY is HP @ 2.5khz w/ 24db slope but now that i'll be runing it @ only 12db but at 3khz, will this hurt the ribbons? I know it plays down to 2khz and even lower but that's with a very steep slope. It seems fine, but I could be wrong. Im still pretty new at diy home audio, so any help will be greatly apreciated. Thanks -shaun |
#2 |
I'd look for more efficent midbasses and midranges to match the LCY
#3 |
i was thinking of going with dual reference but then I would have to build towers for that. So the LCY is going to have be lowered with a L-pad.
| New setup | BERENO | Car Audio | 13 | 10th August 2008 03:14 AM |
| UCD Setup | Beau | Class D | 1 | 10th August 2005 09:48 AM |
| Tx Setup for Reg PS | cantskienuf | Parts | 2 | 1st October 2004 02:50 PM |
| setup | trip-wire | Everything Else | 2 | 2nd January 2003 04:30 PM |
| Page generated in 0.05726 seconds (81.73% PHP - 18.27% MySQL) with 10 queries |
