What is the best way to connect the top to the bottom of my loudspeaker so that it can be remove easily? I'm thinking of connecting them permanently together but that is toooo heavy. This is my first diy speaker so please help me out. I'm stucked in this phase and cannot complete the project. All advice and commets are wellcome.
Thanks Minh |
#2 |
http://www.partsexpress.com/pe/showd...number=260-367
something like this on the underside is what I use about 4 per top should provide quite a bit of shear strength and should be easy to remove vertically I've used them in the past and they are very hard to break (even though they're plastic) if sheared... and they're cheap if you do break one |
#3 | |
This is a riot, a cordless, some hotsauce and the KRS's.... |
#4 |
THANKS Audiophilenoob for the help, but I think there too weak to support the top cabinet. It's really heavy. I used constraint layer damping. Front baffle is 3 layer of 3/4 mdf, 1/8 vinly damping from acoustical solution, 1'' mdf
#5 |
K-amps, thats the kas's not krs's
#6 | |
I think you're underestimating how much force it would take to break these with a shear probably you would have to tip the whole cabinet over and hold it in the air side ways and just let the top fall I don't think you plan to do that do you? |
#7 |
wow! Really, I think I will take a second look. Will have to think of other stuffs to buy from parts express.
Thanks for the help. Minh |
| Bottom Audio 200 | plovati | Clubs & Events | 3 | 8th April 2009 03:49 PM |
| No Bottom E? | TubeHead Johnny | Multi-Way | 82 | 2nd December 2008 02:08 PM |
| The 'bottom end' | PeteMcK | Everything Else | 0 | 18th September 2008 07:18 AM |
| Venting sub out bottom... | Godzilla | Subwoofers | 0 | 5th August 2008 10:55 PM |
| Page generated in 0.09458 seconds (72.56% PHP - 27.44% MySQL) with 11 queries |
