Using a t-line speaker on a car door?
Old 29th August 2005, 08:29 AM   #1
ksl is offline ksl  Estonia
ksl's Avatar
Send a message via MSN to ksl
Default Using a t-line speaker on a car door?
how does the small listening room size affect the sound of a t-line on a car door?
is the idea to use a 4" speaker in a t-line in the car very bad?
blue color
Old 29th August 2005, 04:44 PM   #2
Bose(o) is offline Bose(o)  Canada
It would sound awesome and it isn't a bad idea. As long as the tuning of the TL doesn't go below the longest mode frequency of the car (The longest dimension). I have played extensively with TL's in the automotive environment and the only problem with the TL is finding the space for such an enclosure.
Is that a Nissan Sentra?
ERTW 4 life!
"the day has 24hours. If that is not enough take the night."-Roemhild
Old 29th August 2005, 06:21 PM   #3
ksl's Avatar
this is an example pic from net (mazda 626)
the car in use is VW Golf3 GT (2-door)
so, the difference can be heard? it can be better than just a sealed box?
blue color
Old 30th August 2005, 06:10 AM   #4
Absolutely. All of the work that it takes to figure how the TLs will fit is definitely paid off with the nicer sound of the TL. You'll get even more loading from the TL because of the environment inside the cabin. Since you'll be using this for mid-bass drivers, you'll want to tune the TL near the xo point for the woofer (if you have one).
ERTW 4 life!
Old 30th August 2005, 06:25 AM   #5
sr20dem0n is offline sr20dem0n  United States
Send a message via AIM to sr20dem0n
dumb question, but wouldn't a simple ported enclosure be a lot easier to build and still give a comparable result to TL?
Old 30th August 2005, 06:30 AM   #6
All enclosures have their pros and cons, but I think if someone is able to use a TL, that it will provide superior results.
In my installs, I typically end up using sealed/ported enclosures because of size constraints. Damn them size constraints!
ERTW 4 life!
Old 30th August 2005, 06:49 AM   #7
rcw is offline rcw  Australia
Default transmission lines
The thought that I always have about transmission lines is that they are periodic transmission lines in which people go to a lot of trouble to damp out all of the resonances except the one that occurs at around one quarter wavelencgth of the line.
There is already a device which has an inherant property of having only one resonance and that is called a reflex enclosure. Altogether a lot simpler to design and easier to make, and completely free of the series of resonances that is inherant property of a transmission line.
The difficulty of a reflex of course is that it lacks the mystique of a tl.
Old 30th August 2005, 05:03 PM   #8
Reflex has many more than one resonance and higher excursion than a TL would have below tuning frequency. TL's have better group delay and better mid-bass response, this is why many like TL's and frown upon simpler designs. Reflex has resonances of the actual vent and with a mid-bass driver one would have to dampen this resonances from escaping into the listening area unless they like a cave-type sound.
A superior bass system (a way to control the back wave, ML-TL, reflex, etc, etc.) will always have a better mid-bass response (phase, frequency, CSD, etc, etc.) and this is one reason why TLs have the fanfare that they do.
IMO, TLs and Open Baffle Loudspeakers are superior in sound and if you can't do either then look at a sealed or vented enclosure.
ERTW 4 life!
Using a t-line speaker on a car door?Hide this!Advertise here!
front door speaker placement Dan2 Car Audio 16 12th September 2011 03:30 PM
Does speaker Qts matter in door installations? mda185 Car Audio 19 29th July 2009 08:59 PM
6.5 full range door speaker skooter Car Audio 0 21st November 2007 04:22 AM
Honda Odyssey Front Door Speaker Upgrade Suggestions ReelCat Car Audio 8 9th November 2007 10:11 PM
What speaker specs for a free air install (aka car door)? and other suggestions MITMechE Multi-Way 2 11th May 2002 10:52 PM
Copyright ©1999-2017 diyAudio
