Need help on Series XO
Old 28th August 2005, 02:41 PM   #11
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Most of the info that I have found on series state that they are better with the single series resistor and not an L-Pad and that's what I have found. Even in the parallel world, a lot use the single resistor including Vance Dickason. Yes L-pads do provide a constant load with leaving the tweeter impedance constant no matter what the attenuation is on a parellel network but I'm not sure if that is the case on series network.
The spreadsheet takes the resistor into consideration during the calculation and with your drivers with the series resistor (R1) only gives almost equal impedance on the tweeter leg and woofer leg of the network which is a good thing.
5W resistors are fine and most of mine are non inductive wirewound. Use R1 only (the one in series) as it will sound better but try the L-Pad with R1 and R2 if you like, but that will alter the cap value. As you reduce R1, C4 becomes larger and visa versa.... it's all linked together.
Old 28th August 2005, 05:02 PM   #12
Jennice is offline Jennice  Denmark
Thanks,
I'm eager to try it out when the boxes get back.
A friend of mine is doing the grinding / woodwork as the speakers will probably end up with him... but I have parts to make another pair.
I use the meantime to think (or re-think) the X-over and get ideas....
... and the important help from fellow DIY'ers!
Jennice
I get paid to break stuff. My g/f gets paid to play with children. Life is good.
Old 29th August 2005, 03:26 AM   #13
rabbitz's Avatar
Just try the series crossover and see what you think. The values I gave earlier would not be too far off the mark and should sound very good.
Old 29th August 2005, 06:15 AM   #14
Hi Rabbitz,
I got a call last night: The boxes are sanded to a nice surface, and are ready for paint (we'll let a proff. car paint shop do it).
After that, it's out shopping for components.
Now it's all about getting rid of the flu *cough cough* to get started...
Jennice
Old 29th August 2005, 12:14 PM   #15
rabbitz's Avatar
Sorry to hear about the flu but please keep it away from us...... aaaachoooo.... too late
Old 29th August 2005, 04:52 PM   #16
The day that computer viruses get "personal", I'll cancel my ISP account!
Need help on Series XOHide this!Advertise here!
Three 10" 4Ohm subs, wired in series or series-parallel? Nagamitsu Car Audio 38 19th February 2014 11:16 PM
Quality of Hammond 300 series power transformers compared to 200 series? G Tubes / Valves 10 3rd August 2012 07:32 AM
Yamaha CA-series / CT-series parts DragonMaster Parts 9 19th January 2007 07:48 PM
hafler DH-100 series 2 vs non series 2 dimitri_dimitri Solid State 1 7th May 2006 09:48 PM
Fostex Z series, and EZ series? bbaker6212 Multi-Way 0 13th June 2002 12:10 AM
