#261 | |
#262 |
Well, I was trying to give a laymans definition, but this is certainly true
Strictly speaking I think we are after zero phase filters here, which are a subset of linear phase filters. People seem to use zero phase and linear phase interchangeably, but of course this is not quite correct Ed W |
#263 | |
I have however compared the Lynx/Apogee to the 9632 and then the fireface to the Lynx/Apogee. So I've got points of reference for performance. My thoughts on the 9632 vs. Lynx/Apogee were posted earlier in this thread. I was looking at the 8-way ADC/DAC when I bought the Apogee. Its DAC's are spec'd somewhat similar to the 9632 with 112dBA SNR etc., although its ADC section is superb with 117dBA SNR. Seems to me that the RME ADI-8 is around 5 years old and getting on now. Newer DAC's like the AKM's top of the line AK4396 in the fireface have since appeared with 119dBA SNR etc. Bottom line is: There's a very definite improvement from RME9632 -> Lynx/Apogee but from that to the fireface there's little difference between them, though I'd give the edge to the Lynx/Apogee setup with a slighty more focused sound. |
#264 |
double post
#265 |
Ed,
From what you are saying it would be definately worth my while employing a linear phase filter(s) between my mains and subwoofer. Shin, If I buy the Fireface I will be able to use console and Waves or the free LP equalizer to do this, right? The only part I didn`t understand is the RTA (real time analysis) part. Does this involve employing a mic and some additional software to measure the result of the crossover filter(s) you`ve created? If so, could you please explain the software required and the exact procedure? Thanks geoff |
#266 | |
There are some limitations in how they implemented multi-channel waveout drivers but for simple stereo it should work fine. |
#267 | |
The best thing to do Geoff is to download the trial of Console and try routing audio from foobar, winamp etc. through it and see if it will actually pick it up by using the level meters within console. If it works your all set to go, if not then my original comments stand. Can someone please confirm if the EMU cards work and if so I can add them into the list of compatibles. |
#268 | |
#269 | ||
#270 |
Thanks dwk,
If you get it to work, I'll add it to the list and that will certainly open up another price point for others interested. |
| Page generated in 0.13110 seconds (80.07% PHP - 19.93% MySQL) with 10 queries |
