Old 22nd August 2005, 09:17 AM   #1
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
Default 3-way Seas design
Hello,
I am designing a pair of floorstanding speakers for a friend of mine and he has given me a budget of $1000 before cabinets. I have contemplated a few designs and think that the following 3 way design could be very solid. I had originally thought of a MTM design consisting of the Vifa XT25 tweeter, and either 2 Vifa XT18's or 2 Extremis 6.8's.
The 3-way seas design is as follows:
Woofer: L26
Midrange: MCA12
Tweeter: 27TBC
I have always worked with 2-way designs before and was a little scared about the complex crossover required for this system. I have come up with crossover frequencies of 700Hz and 3500Hz, all 2nd order and impedance compensation (zobel) on the woofer and midrange. The tweeter is then attenuated to match sensitivities.
According to my simulation software, the -3dB point when using the L26 is 31Hz in a 2ft^3 box. What I am concerned about is the crossover. I don't want there to be distortion because I am forcing the speakers to play frequencies they can't handle.
It would be very helpful to me for someone to comment on this design as I am sure there are many members here that have experience with the Seas drivers.
THANKS
The power of Science compels you!
Old 23rd August 2005, 03:57 PM   #2
DcibeL's Avatar
I guess since there are no replies that this is a solid design and there are no problems with it? I am also open to other suggestions as to what I could do for a pair of towers for <$1000 for everything less the cabinets. There will be no subwoofer in this system so getting nice low frequency responce is key.
Old 23rd August 2005, 04:06 PM   #3
Taco is offline Taco  Netherlands
There are a lot of options about which drivers to use, but I see no problems. I never used those drivers, so I cannot comment if the match is alright. But you cannot go wrong with Seas. I have made a 2-way using the 27TDC and 18cm paper woofer from Seas.
I have only one suggestion, try to cross the L26 @400Hz to the midrange. You want to cross the L26 as low as possible to avoid energy storage in the aluminium cone.
Maybe you can also look at the Dayton RS180 combined with 27TDFC / 27TBFC and those new 12" Dayton drivers. Or those new Peerless Exclusive 5" or ...
Old 23rd August 2005, 04:14 PM   #4
HI,
IMO 700Hz is a bit high........I believe 500Hz is possible.
regards,
Old 23rd August 2005, 04:24 PM   #5
DcibeL's Avatar
Thanks for your replies. I think that in order to cross the L26 at anything lower than 500Hz I may need to pick a different midrange. I want to order all the parts from Solen so the Dayton driver is out of the question, but maybe peerless. I had wanted to use the MCA15 instead of the MCA12; Solen has it on their site, but I cannot find it in the price list.
I guess I have some more experimenting to do.
Old 23rd August 2005, 04:31 PM   #6
Send a message via AIM to 69stingray Send a message via MSN to 69stingray Send a message via Yahoo to 69stingray
Here is someone's project with Seas speakers in a 3-way setup. May be interesting reading for you.
Doug B's Seas Three Way Towers
Audio DIY Page
FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account.
Old 23rd August 2005, 04:38 PM   #7
(sorry for my english)
Dcibel,
IMO 3500Hz is ok for a 4" but not for a 5,25" !!
Anyway a 4" seas hystorically sounds good from the midbass to the midhigh!! (11-FGX etc)
If you can live with minor 2-4 dB spl max.........
regards
Old 23rd August 2005, 04:42 PM   #8
zobsky is offline zobsky  India
zobsky's Avatar
Default Re: 3-way Seas design
Originally posted by DcibeL
Hello,
THANKS
a bit out of context , but for $599 US, .. RAW acoustics has a 3 way kit using a single extremis , wr125s widerange, ribbon tweeter, x-over etc http://quicksitebuilder.cnet.com/wrn...erieskits.html . i'm in the process of helping a friend build one of these so can't report on performance yet, but thought it might be inline with what you're going for.
"Any fool can know. The point is to understand" - Albert Einstein
Old 23rd August 2005, 07:37 PM   #9
DcibeL's Avatar
I think that if I lower the low crossover to say 500Hz, and insead of the MCA12 I'll use the L12 for the midrange it should be a very nice speaker. The L12 will also keep the speakers aesthetically pleasing because now the drivers will match . I'll just have to make sure that the resonant peaks are taken care of in the crossover.
I will be talking to my friend on the weekend and we'll see what he thinks of this.
Old 23rd August 2005, 08:04 PM   #10
DcibeL's Avatar
So my final design now uses the L26, the L12, and the 27TBC. Crossover points are 600Hz and 2500Hz, all 2nd order except the lowpass on the L26 is 3rd order. The only thing I don't like about the L12 is the frequency response starts to roll off at 1000Hz so there is a will be a slight dip in the frequency response when using this driver.
Thanks guys for your help.
Has anyone built the Seas 'Mimir' design? Tony D. Multi-Way 5 15th May 2009 07:53 PM
Need enclosure design for Seas CA17RCY apaulr Multi-Way 0 5th July 2008 02:41 PM
3 way scanspeak - seas design patchwork Multi-Way 4 28th January 2007 02:31 AM
John K's Seas Design, Questions demon2091tb Multi-Way 13 7th December 2005 12:52 PM
Seas W18, sealed or ported design? graks Multi-Way 0 9th May 2005 07:24 AM
Page generated in 0.11575 seconds (82.49% PHP - 17.51% MySQL) with 10 queries
