Old 22nd August 2005, 04:20 AM   #1
Default Sneak peak into my latest project... pics ;)
So I finally got to the point I'm ready to veneer...
after over 300 man hrs working on this... 1.5 months... $4700... and blood sweat and tears...
there's something to show everyone
these speakers are "inspired" by the Avalon Sentinel... the front view is quite similar...
unfortunately the pics were taken at night... so it's hard to see EVERYTHING nice about these speakers
the bass cabinet is identical to the Sentinel... with the large triangles cut in the corners ... but a little more "low profile" than with the real sentinel
the bass cabinet has 2 curved walls.... which were built around a frame with 3 3/4" MDF supporting braces and the 1.5" top and bottom
the top and bottom are supported by 1.5" dowels in the rear... this gives quite a bit of added strength...
the curved walls were made up of 4 layers... first layer was .25" birch .... which was curved around the shape... then 9 layers of fiberglass mat and resin were applied to each curve.... making it 1/2" OF SOLID GLASS. at this point it's strong enough.... way more than strong enough... my 250lb friend jumped up and down on this and zero flexing occured... however over top the fiberglass one layer of 5/8" birch ply was layed... then another layer of 5/8" pine ply
the backs are 1.5" MDF...
the baffles are 1.5" MDF... routed out to flush mount the 15's...
they were then reinforced on the inside with 4 layers of fiberglass... this is so ridiculous and unneeded... but I was paranoid
the whole bass cabinet is ported to 32 hz... and is roughly 10 cubes
the cabinet weighs in at 250+ lbs without the speakers
the front of this will have 1/8" rubber on it just like the sentinel
the pics are again hard to see... but there is a "gap" between the top and bottom parts just like the Sentinel... which will be rubber also
the tops are angled on... well every side
the midranges are flush mounted into a piece of 5/8" with 60 degree edges to cut down on defraction off the baffle
they are in an irregular triangle box that's internally chambered specifically for the optimal performance of them
the tweeter opening fits the oak flanges I made for the LCY copy ribbons I made...
they're getting veneered tomorrow... with 2 4x8 sheets of precision matched walnut burl
then I whip out the HVLP and put on 10 coats of lacquer
Old 22nd August 2005, 04:21 AM   #2
top back
Old 22nd August 2005, 04:23 AM   #3
top front up close
Old 22nd August 2005, 05:33 AM   #4
44 views and not even a single
"looking good"
or "wow"
Old 22nd August 2005, 05:41 AM   #5
looking good
wow
but for real though, i wish i had ur guys' skill when it comes to cabinet making.
Old 22nd August 2005, 05:48 AM   #6
Originally posted by lemans23
looking good
wow
patience... and dedication is all that it takes
300 hrs is quite the project lemme tell ya
Old 22nd August 2005, 05:52 AM   #7
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
they look kinda flimsy...
Old 22nd August 2005, 06:02 AM   #8
lol..... yea....
Old 22nd August 2005, 07:28 AM   #9
Taco is offline Taco  Netherlands
Wow great skill, what kind of dampening will be installed? (bitumes, foam, BAF)
Old 22nd August 2005, 12:31 PM   #10
wigginjs's Avatar
What drivers? Active or passive?
The Four Chairs
DIY Home Theater
Sneak peak at my Fe166ESR project and a 'Pass' question. Illusus Full Range 27 4th April 2005 04:22 AM
Share pics of my latest loudspeaker design rcavictim Multi-Way 14 17th September 2004 08:16 PM
New Movie Sneak Pics.......... mrfeedback Everything Else 2 7th January 2004 09:59 AM
pics of latest project revisorn Multi-Way 3 5th September 2003 03:44 PM
PICS: My latest speakers...At last! Rarkov Multi-Way 35 28th May 2003 08:09 PM
Page generated in 0.11111 seconds (78.22% PHP - 21.78% MySQL) with 11 queries
