Old 21st August 2005, 01:45 PM   #1
paulhfx is offline paulhfx  Canada
Default PTP Active Crossover Wiring
I'm in the later stages of designing and building a 4-way dipole. I've built a breadboard prototype crossover, and modified/adjusted so that I'm ready to build the crossover. I want to do them with point-to-point wiring, (I have no resources or interest for a custom pcb) and have some newbie questions.
What sort of boards should I mount them on? Fiberglass/wood/plexi/doesn't matter?
How do I connect the opamps?
Thanks,
Paul
Old 21st August 2005, 01:57 PM   #2
soongsc is offline soongsc  Taiwan
soongsc's Avatar
If you're just thingking about using existing boards with those little holes in them, then just use IC sockets for the opamps.
Hear the real thing!
Old 21st August 2005, 06:59 PM   #3
Should I use boards with pre-drilled holes? If so, should they be copper-lined or bare?
If I use IC sockets, how do I connect wiring to the ic sockets - just solder into the same hole in the board?
Thanks,
Paul
Old 22nd August 2005, 01:35 AM   #4
soongsc's Avatar
Paul
Assuming that you don't want to have custome made PCBs, then you could use boards like shown in the pics. These have predrilled holes and copper pads. You can also look for some with traces connecting multiple holes to make connecting multiple components to a single point easier.
Thanks,
Paul
If you select a board with individual pads, then you can plug the components in and solder the pads together. If yoou get the ones with traces that already connect multiple holes, then use that to connect the components and wiring.
Help w/crossover wiring babgrip Multi-Way 7 13th December 2008 07:00 AM
2 chipamp's per speaker (active) wiring advice? morepower4me Chip Amps 4 12th July 2008 09:26 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
MTM center channel wiring with 2 way active crossover mik Multi-Way 0 2nd April 2004 11:39 AM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Page generated in 0.07460 seconds (75.07% PHP - 24.93% MySQL) with 11 queries
