Old 17th August 2005, 11:56 AM   #1
tcpip is offline tcpip  India
Default What's the equivalent of multiple drivers?
I was trying to model the vented box for a line array that a friend is keen to try --- the inspiration for my friend is the Bottlehead Straight 8. This line array which I'm toying with will have six 5" drivers in each box, plus a dome tweeter perched above them. Since this is six drivers, Unibox doesn't know how to do the calculations out of the box (pun not intended), so I need to synthesize the parameters of a hypothetical single driver which will be equal to the combination of all six put together. Then I can tell Unibox that I have just one driver, and ask it to do its thing.
I was thinking of making two series-strings of 3 drivers each, and then paralleling these two strings. Since each driver's Re is about 6 Ohms, I'll get a final configuration with an Re of about 9 Ohms, which should be easy on the amp.
My knowledge of the equivalent T/S parameters is a bit flaky, so I thought I'd ask for your guidance. Please can you tell me whether each of the points below are correct?
  • Vas and Sd of the equivalent single driver will be six times the corresponding values of each small driver.
  • Qts of the equivalent driver will be the same as that of each driver. (Will it? Will the Qts depend on the electrical connection topology of the drivers? Will I have to wire up six drivers on an open baffle and take impedance measurements to get the Q of the final setup?)
  • Re will be 9 Ohms as described above.
  • Le will be calculated using formula for series and parallel impedances just like I did with Re.
  • Fs for the equivalent single driver will be the same as that of each small driver.
  • Xmax for the equivalent big driver will be the same as that for each small driver.
Incidentally, I've read the section on compound woofers in Dickason's Cookbook, and I'm quite confident I've understood how to calculate equivalent parameters for two drivers. I'm just not certain how to do it for six, specially since some posts on this forum have mentioned that damping changes sharply if drivers are connected in series, etc.
Did I miss out anything? Am I on the right track?
Old 17th August 2005, 02:44 PM   #2
bobhayes's Avatar
I think you've covered it pretty well.
Dickason states that with two woofers, the Q remains the same, so three should also remain unchanged for the purposes of your calculations.
Paralleling them to another chain of three woofers would bring the parameters closer to that of a single unit, if there was any doubt.
I would go ahead using the theory you stated.
Old 17th August 2005, 02:46 PM   #3
Take the basic sensitivity on the speakers and you can get the params for multiples this way.
If the single speaker is 88 a 1m 1 watt then
Array efficiency= 88 + 10*(log of the n number of drivers)
Array efficiency= 88 + 10*(log 6)
Array efficiency= 88 + 10*(.78)
Array efficiency= 88 + 7.8
Array efficiency= 95.8
I'm not so sure I wouldn't put the tweeter in the middle of the drivers... i.e., MMMTMMM.
If you are on a budget, try the dayton neo tweeter... 5 bucks sounds pretty good.
Series/parallel is SOP for arrays.
Start building now. You will never go back. Try it first in an open baffle. You might save yourself alot of wood.
The other reading is Jim Griffin's paper on line arrays.
Griffin on line arrays
Old 17th August 2005, 03:07 PM   #4
tade is offline tade  United States
Send a message via AIM to tade
definitely put the tweeter in the middle! the line array effect is very pronounced...
Old 17th August 2005, 03:31 PM   #5
RJ is offline RJ  United States
Nice experiment, but the enclosure is going to be tall. Taller then 34".
If the box is going to be ported the tall box will act as a tube creating standing waves which will screw up the port resonances. In essence it'll be a hybrid transmission line - bass reflex.
My experience with line arrays has taught me to build them in seperate boxes. My first array started out to be ported. I could never get the port tuned right. I then added baffles to load the drivers and break up the standing waves and I still couldn't tune the port. I went sealed and loved it. It still had bass and more then I expected.
The line arrays I'm building now 'are' in seperate boxes. 3 of them to be exact. The 3 will be glued together and an outer cover of finished plywood and 1/2" MDF will cover the seams and add a constrained layer to the box to help stop box resonances. Making them sound dead.
You could also add a shelf half way in your box thus making two seperate enclosures. 2 ported boxes will be easier to tune then one tall one.
Have you checked out Dual Chambered Reflex Boxes???
http://www.diysubwoofers.org/prt/dual_chamber.htm
http://paginas.terra.com.br/educacao...negro/english/
If the 5" drivers model well with 2 ports then this would be a good direction to go. It's sound and characteristics is that of a cross between sealed and ported. Better group delay and no below resonance flutter from the driver.
Just adding fuel to the brain, Good Luck! ,Rudy
Oh yeah, the formula for transmission lines are;
(1128/Fs of the speakers) /4 = 1/4 wave in feet
Feet x 12 = length in inchs
If the driver Fs is 55 hz. then 1128/55 = 20.5 ft.
20.5/4 = 5.13 quarter-wave feet.
5.13 x 12 in. = 61.5 "
A 32" tall box would create 1/8 wave resonances or harmonics.
I think the 1st or 2nd harmonic is the killer, not sure. I'm gonna check on that.
http://www.quarter-wave.com/
Old 18th August 2005, 01:13 AM   #6
simon5 is offline simon5  Canada
You could just use WinISD Pro that simulate up to 100 drivers.
DIYaudio for President !
Old 18th August 2005, 04:06 AM   #7
just another
wintermute's Avatar
Doesn't winisd pro only allow modelling with drivers in parallel??? or did I miss something
Actually I just had a look, and there was a newer version (one point rev higher than I had) and there are a lot of nice new features.... but on playing with multiple drivers it doesn't seem to calculate the impedance at all.... no matter whether I put in 1, 2,3 or more drivers the only change to the impedance plot is a slight change in the resonant freq, the overall magnitude stays the same.... not how it should be me thinks
Tony.
Any intelligence I may appear to have is purely artificial
Some of my photos
Old 18th August 2005, 05:03 AM   #8
Thanks guys. You all are amazing. You've not only answered my questions, you've touched upon some of my unspoken fears and doubts.
First of all, I'm glad that the equivalent driver parameters thing has been sorted out. Thanks for confirming that I'm on the right track.
Now for my thoughts and plans. I'm playing with this driver from Peerless India.
(This driver is quite interesting even to non-Indians, incidentally, because a modded version of this has apparently been supplied under OEM order to GR Research and is sold in the North America as their famous M130. The key diffference between what I'm getting here and what the M130 gives, as far as I can see, is the Fs.) I'm getting an Fs of 80Hz, much higher than I'd like.
The published parameters are tallying well with my SW-measured values. The Vas that I got after my quick-and-dirty added-mass measurement is about 4.8L. (I'll do a sealed-box measurement later.)
So, for a vented box of 5L per driver, I'm getting a manageable 30L total internal volume, but that's too little bass (F3 of box at 58Hz or so). Using Unibox and moving to something like 15L per driver, I can drive down the F3 to about 44Hz, which, together with a down-firing port and ground coupling, will probably give me adequate bass. (Remember, I'm new to all this, I could be wrong... so please shout loudly if you think I am.)
Therefore, at a total volume of 90L, plus lots of bracing, I'm looking at a box which is tall and slim from the front but will probably extend more than two feet at the back. So it won't be a slim and sexy column any more, except from on-axis. And then comes the problem of vent diameter. With an equivalent driver diameter of something like 15", I don't think I should use just a 2" vent. So I wanted to build a 4" or 6" vent, and that makes the duct quite long.
I had toyed with the idea of doing one chamber per driver, maybe with each having its own slim little ducted port. What should I do? Regarding the TL behaviour of my big box, I don't think that danger is very serious. This is because at 90L, I'm not going to get a tall slim box... I'll probably go for a large box with narrow front baffle but with a sloping back, extending to a base which might be two feet long. In other words, the shape of my enclosure may be more like a triangle than a column. See the Aksonic speaker's design to get an idea:
except that my box will probably extend at the back much more.
Therefore, I'm now wondering whether I should go in for one large down-firing port in one big triangular box, or whether I should make multiple chambers, each with its own vent. (With the multiple-vent approach, I lose the ability to have a down-firing port to enhance bass via ground effect.)
What do you think?
Another thing that I was wondering about was the tweeter. I had originally thought I'd put it on top, like the Bottlehead Straight 8. But do you feel a tweeter in the centre is much better? If I do that, I can increase my box height too, and then maybe my box will begin to look like your tall slim columns. Which is better?
Old 19th August 2005, 01:48 PM   #9
Yeah, but it will give you an idea about the SPL curve. If you have 4 drivers in series-parallel the impedance will stay the same and WinISD will show you the new SPL you can achieve with the same power imput.
Also, if you know some maths, you can easily guess what will be the impedance curve if you put only two drivers in series (multiply impedance curve by two) )or two drivers in parallel (divide impedance curve by two).
Because you know the new nominal impedance, you can easily calculate the SPL sensivity at 2.83 volts too.
Old 19th August 2005, 01:52 PM   #10
Your equivalent diameter is big yes, but the Xmax is low, so the vent speed will be OK. You could double check it in WinISD Pro. I would use a single 3 inches vent or 4 inches if you want to go overkill.
The tweeter should be at ear level. So unless your column is very high, it should be at the top of it.
Good luck!
Multiple drivers in MJK's sheets? GuyPanico Multi-Way 6 31st May 2005 03:46 AM
Sensitivity of multiple drivers? Snickers-is Multi-Way 25 8th February 2005 04:47 AM
understanding max spl with multiple drivers RyanC Multi-Way 23 18th July 2004 06:48 PM
TS of multiple drivers Havoc Multi-Way 3 18th March 2002 06:09 PM
Working with Multiple Drivers? Ignite Multi-Way 6 31st July 2001 11:46 PM
Page generated in 0.18619 seconds (81.98% PHP - 18.02% MySQL) with 11 queries
