Old 15th August 2005, 04:52 AM   #1
just another
wintermute's Avatar
Default problems with acoustic measurements
I've been doing acoustic measurements of my prototype MTM speaker and have been having some problems.
I'm using speaker workshop and a Wallin II preamp with a panasonic WM60AY capsule (not linkwitz moddified).
I just discovered one what one of the problems is. the phase plots I have been getting seemed wrong compared to a couple that I had (where I must have accidentaly reversed the polarity). I've attached the two plots below.
the top one is with the speaker wired with correct polarity tested with 1.5V cell (when connected +ve battery terminal to +ve speaker get an outward movement of the cone).
the bottom one is with the speaker wired with reverse polarity.....
so:
1. Is the bottom graph how my phase should look??
2. Is it likely that my amp or mic preamp is reversing the phase??
3. should I connect my speakers up with the polarity reversed at the amp terminals?
I have another question regarding the freq response. but I'll leave that for a while so as not to confuse the issue
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 15th August 2005, 11:38 AM   #2
tcpip is offline tcpip  India
I'm reading your thread very carefully, waiting for answers from others. This is one bridge I'll have to cross very soon now... I'll be doing SPL measurements for the first time in my life sometime in early September. And I too have Speaker Workshop and a Panasonic capsule, unmodified.
Old 15th August 2005, 11:57 AM   #3
The phase plot doesn't really become important until you start measuring multiple drivers and attempt to concoct a crossover for them. Your nearfield phase measurement is just showing you that if you reverse the polarity of the signal to the driver the phase will shift...theoretically 180 degrees. Nearfield response is usefull for looking at how a driver behaves in an enclosure at lower frequencies, or for examining frequency response aberations the driver may have, but you won't be using it to develop a crossover, so phase isn't important at this point.
Old 15th August 2005, 12:59 PM   #4
just another
wintermute's Avatar
Hi Jbateman,
Probably not important right now, but I will in future be crossing (actively) over to stereo subs (and was planning to do it at about 300Hz).
What concerned me with these plots was the phase doing a reversal at exactly that point (ie 300Hz) when the driver is wired up with correct polarity.... I haven't built new cabinets for the subs yet so haven't done any measurements on them, they are currently the bass drivers in my existing 3 Ways , but because of the low freq's involved I figured that I could only use near field (or possibly ground plane) measurements for this part of the project. Sorry I didn't include that detail I moved this from the other thread I had going because I figured it wasn't on the topic of that thread, and I guess I forgot to put in some details
So in that context would a phase reversal at 300Hz be an issue?? (my feeling is that it is a big one) and if it is should I be running the midbass and subs in reverse polarity?? I guess this question is a little pointless without measurements from the subs.....
I also have a concern about the phase on my gated measurements... it just doesn't look right, its inverting all the time and is very jagged, like a saw tooth......
Attached is an example. I'm not really happy with this. The resolution is too low due to not being able to get better than about 7ms gate time. I will try and do some outside measurements on a still day, but this is what I can get at the moment.
The measurements were taken at a distance of 1M with mic 1.25M off the floor (1.5M to ceiling), egg crate foam on the floor, and no other nearby walls or objects. Gate time was set at 6.8ms (much higher than floor or ceiling bounce would occur at but based on the pulse response I thought it would be ok. Changing to a gate time of 3.5ms just made the resolution woeful.
This is a measurement of both of the MW144's mounted running in parallel full range..... hmmm writing that statement, I just wondered whether or not the phase data is all over the shop because there are two drivers involved..... the measurement is taken midway (height wise) between the two drivers. maybe I should measure just one
Tony.
Some of my photos
Old 15th August 2005, 01:12 PM   #5
just another
wintermute's Avatar
Hopefully we will both get something out of it ..... I'm getting semi usefull results, but I'm not confident I can use them for crossover design, I have a glitch or two somewhere I'm sure!
I've successfully used SW for getting T/S params in the past, and I've played with accoustic measurements too and come to some usefull conclusions from what I have measured, but this is my first time designing a crossover, so I want to make sure I'm not working with completely bogus data
I found with the mic capsule that the modification actually made things worse. Unless you are planning to test at high SPL's I wouldn't recommend doing the mod. It will reduce the gain of the mic considerably. for measurements at 1M you will require excessively high SPL's to overload an unmodified mic (If you don't have hearing protection on I think you will have damaged hearing I can't see any reason for doing the mic mod personally unless you want to do high level nearfield testing.
Tony.
Some of my photos
Old 15th August 2005, 01:28 PM   #6
Josephjcole's Avatar
Just so you know it's is not actually "inverting". When the phase goes above 180 degrees it will look like it inverted, but it is simply going to 181 degrees. When you look at it try and mentally unwrap it. Hope that helps.
Joe
Old 15th August 2005, 01:38 PM   #7
just another
wintermute's Avatar
Thanks Joe that makes much more sense! I guess I've seen lots of stuff saying that the phase shouldn't be changing rapidly at the crossover point and thought it was these (seemingly odd) inversions.... thinking of phase as rotating through 360deg and eventually working its way back round to zero makes much more sense!
I still don't actually understand why the phase changes (non-linear reproduction of the sound by the driver??), but that certainly clears up one incorrect interpretation that I had
Tony.
Some of my photos
Old 15th August 2005, 01:40 PM   #8
You are right that it would be difficult to make an ON AXIS measurement at 300HZ. On most 3 way speakers with a 2nd order xover around 300Hz, the midrange is connected in reverse polarity. If you were to try to determine this by making nearfield measurements you wouldn't be succesful, as the mic is in a different place for each driver...therefore the phase data is not usefull.
Most of the time people will connect their sub polarity based on listening preference...set it for whichever sounds best.
As for the "zig zag" phase plot, this is due to the long path the signal must travel from driver to mic. Some call this the phase rotation from the Time of Flight...or EXCESS DELAY. You can remove this delay by using your pulse graph. In the example picture below, I show the original phase plot, then my pulse which starts at 8msec. Next you would hilight the original chart, select TRANSFORM/DELAY, then enter the estimated time of flight. In my case I enterred 7.4msec, which produced the bottom chart. NOTE: Be sure to UNCHECK the REMOVE EXCESS DELAY box when you do this.
Old 15th August 2005, 02:30 PM   #9
just another
wintermute's Avatar
Thanks jbateman that little peice of information was invaluable and makes me feel a lot better about my measurements I now have a normal looking phase plot for the midbass measurement!
I guess with the subs I'll suck it and see, but I think that's a little way off yet
I'd looked at page 122 of the unoficial speaker workshop manual titled excess delay, and had stopped reading when it said it is not recommended to do this..... I hadn't read the next bit that said to untick the excess delay box, and clean up the phase of the individual driver!!! might dig up the sw manual two thread and add this in
I've noticed one thing though (questions questions)... in my pulse measurement the pulse starts at 3.1ms I tried putting that in and got rubbish, then I tried 3.0ms and still got rubbish, 2.9ms seems to give an ok result, if I change it to 2.8 it's also ok but different to 2.9..... top graph with delay set to 2.9ms bottom one set to 3.0ms.... I'm guessing going with the result closest (but less than the pulse start time) that gives a decent result is the way to go.
Tony.
Some of my photos
Old 15th August 2005, 02:44 PM   #10
I don't think it's too important the exact amount of delay you remove. The goal is to remove the same amount from your midwoofer and tweeter measurements, so that you can more easily compare the phase in the crossover region (when you develop the crossover)
In my example above, the little glitch in the impulse graph at about a half msec is some leakage between the 2 channels on my soundcard when the pulse is generated. So I subtract that from 8msec when the pulse arrives to get my time of flight.
Unhappy Ice amp eAR Acoustic Reality service problems Al.M Class D 2 20th December 2009 02:18 PM
Ice amp eAR Acoustic Reality service problems Al.M Chip Amps 1 10th April 2009 10:31 PM
XAB Measurements DarkOne Pass Labs 12 16th April 2006 10:59 PM
Acoustic pre-amp james27_84 Instruments and Amps 4 23rd March 2005 06:49 PM
anyone have measurements of TB 871? morbo Multi-Way 5 27th November 2004 03:10 AM
Page generated in 0.15716 seconds (74.69% PHP - 25.31% MySQL) with 11 queries
