Old 23rd August 2005, 02:48 AM   #41
Audist is offline Audist  United States
Originally posted by amirmk
I've yet to decide on the design and drivers, I Like the Accutons.
The Tweeter i like is the C24-6 but i have trouble choosing the mid woofer. Accutons are both very expensive and are only about 86dB's. Choosing the even better 23 tweeter with 89dB's would make my 2A3s useless. Do you have any ideas about an efficent 7-10" woofer?
Why not use with Morel Supreme 110 tweeter?
People say that Morel S.110 is very similar in sound quality to Dynaudio Esotar D330T.
And because you live in Israel, you can save a lot money with Morel.
Old 23rd August 2005, 01:35 PM   #42
amirmk is offline amirmk  Israel
I can use Morel 110's, it's not a big issue. The bigger problem is the crossover for me.
Johan, why sealed boxes?
Old 23rd August 2005, 02:00 PM   #43
JohanH is offline JohanH  Netherlands
Default Sealed Boxes
Same reason DJNUBZ mentioned: I prefer the clean bass a sealed enclosure produces over the sound of ported boxes. Somehow they never sound quite right to my ears.
Old 23rd August 2005, 02:02 PM   #44
Amir,
Give George Short a call and order a pair of these:
http://www.northcreekmusic.com/Pegasus/Pegasus.htm
The price is right. The designer is a pro. This is probably one of the best monitors in the world. Carefully matched drivers and crossover components.
Shipping is costly though, his filters are heavy (HEAVY).
I don't think you will ever reach the level by going the diy-route.
Just a thought,
Franco
Old 23rd August 2005, 08:30 PM   #45
I think i've decided. The project is Mr. Gravesen's "Super Mini-Monitor". http://home1.stofanet.dk/troels.grav...5CY001_OWI.htm
I heard another design by him, the Acapella, and it is spectacular. I would like to build the monitor with Seas W18Ex instead of W15 (I can get them for free, and I wouldn't like to but a new pair of 300$ drivers), Mr. Gravesen says that it is impossible to change his complicated design without specific data, which i would only be able to get in several days, so i would like to ask you what changes would you do to his crossover design so it will accomodate the Seas' bigger borther.
Old 23rd August 2005, 09:21 PM   #46
DJNUBZ is offline DJNUBZ  United States
Franco those speakers look like a great design. I have been on the north creek site before but not seen them. Are they new?
Old 23rd August 2005, 09:28 PM   #47
Amirmk,
To change the woofer in Mr. Gravesen's design is essentially the same as a whole new design. You would need a larger enclosure and a crossover network change to use the Seas W18 driver vs. the W15 in his original design. Hence, a different box and a different network. What is left is nothing.
If you wish to build his design, I would recommend that you build the W15 design that he posted and build it exactly the same as his documentation. Otherwise you might as well open your window and throw your money out of it.
Jim
Old 23rd August 2005, 09:52 PM   #48
Designing a new box is no problem for me, I have a degree in physics, and i was not going to use his exact enclosure in the first place, i just want to know what changes could be made to fit the driver.
Old 23rd August 2005, 09:58 PM   #49
morbo is offline morbo  Canada
A different driver needs a totally different network. As do different baffle dimensions. If you are going to go to all the trouble of making the 'best' 2way, why compromise it like this? Stick to the published baffle, XO and drivers, they were designed as a system.
Also, what Mr. Graveson refers to as specialized data, is a measurement of the new woofer in the baffle of his existing design. Since the larger woofer would probably require a larger baffle, this would also mean a measurement of both the original tweeter and the new woofer in the new baffle, and a new crossover design. Honestly if you have free access to the other woofer, you should just find a design that uses it.
Old 23rd August 2005, 10:08 PM   #50
Can you think of any 2Way bookshelfs that use the Seas W18ex?
Thanks.
FS: Highest quality Piezo drivers audiokinesis Swap Meet 6 21st June 2009 09:51 PM
Highest quality Dip sockets? AudioX Chip Amps 1 11th June 2009 11:13 AM
Highest quality design D_o_S Solid State 45 20th January 2008 08:05 PM
Advice on highest quality full range driver deandob Full Range 39 13th December 2005 02:45 PM
PGA2310 - Setup for highest audio quality ALBQ Solid State 0 22nd August 2005 03:40 AM
Page generated in 0.30884 seconds (31.56% PHP - 68.44% MySQL) with 11 queries
