Bohlender&Graebener Neo 8 Magnetostat
Old 4th October 2002, 07:51 PM   #21
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Tomahack,
Awesome. That picture really puta an exclamation mark on the tread...
Those peerless are quite excellent too, but i only played with a single pair.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th October 2002, 07:53 PM   #22
tomahack is offline tomahack  Canada
Dimensions are 86"x9.5"x16". The baffle is 1.5" MDF. The enclosure is heavily braced. One brace per driver. I used Black Alsphat Saturated Felt on all surfaces except the baffle. Same with Grey Convoluted Open Air Cell Acoustic Foam. Veneer is African Bubinga. Internal wires are QED Silver Anniversary. Total cost of the project: around $3000 Canadian which is not much in U.S. currency
Old 4th October 2002, 07:58 PM   #23
Another view
Old 4th October 2002, 08:15 PM   #24
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Is that another line array on the left with Stryke Audio SA071 7" drivers? Is it any good? They are on sale for $10 each for 8+ at stryke.com I haven't bought any, but was considering it for cheap projects.
Brian
Old 4th October 2002, 08:36 PM   #25
Yes they are SA071 Brian. For the price, it is indeed a good driver. Probably the best buy you can make for $10. But from my experience with them, you should Xover them below 2000Hz@24dB/oct.
Old 9th October 2002, 02:52 PM   #26
diypole is offline diypole  United States
Default Hey now
Tomahack,
Be-aaaa-utiful job, I would be scared to put a watt through those. I am about an hour away from you, right on the Canadian border in Northern Vermont, about a mile into the woods on a dead end private road.
Thanks for the crossover info. How are those neo 8's mounted?
I cannot bear to raise the crossover frequency, so have been experimenting with an asymmetrical cross at 4-600 hz with 48db/oct on the neos and 24db/oct on the Peerless csx. I have settled on an MTM design with the 10" peerless wired in parallel. I thought this would bring the sensitivity of the woofers from 88 to 94db, which would match the neo's 93db nicely, but didn't coun't on the rear radiation from the dipole, which increased it to 100db! I am also using a Marchand cross...eerie.
Last night I sat about 4 feet away from them in my cellar with about 20 ft behind them. These speakers dissapear, and set a firm, wide image well behind them. On track 13 of big head todd and the monsters' Midnight radio ( all 2 track digital live), the guitarist was sitting about 12-15ft in front of me.
The Peerless composite sandwich cone is very smooth, yet with 9mm x-max, four of them can shovel some serious air in a dipole, and bass is satisfying without the subs. A freinds wife is buying these for him this christmas, and I am now looking at the 28" ribbons for my own speakers!
Unbaffled
Old 9th October 2002, 03:49 PM   #27
Thanks diypole!
If you happen to go to Montreal, let me know. The Neo8 are wired by pair in parallel and then the four pairs are in series for a total impedance of 8 ohms. The HDS are tapered. Driver 1,2,3 in series (24ohms), driver 8,9,10 in series (24 ohms), driver 4,5 in series(16ohms), driver 6,7 in series(16ohms). The four groups are paralleled (total impedance of around 5ohms).
I will probably try a lower Xover frequency when I will have the time. Something like 1000Hz. Are you satisfied with the treble extension of the Neo8 above 12kHz with only one driver? What are you using as a source and electronics?
Old 9th October 2002, 07:08 PM   #28
And if you should come to vermont, let me know also.
I am still in cellar mode, where I am ALLOWED to tinker with unfinished (not pretty yet) stuff after the kids go to bed, LOL. I can't wait to hear these up in the main system for a while before they go, but for now I am just feeding them with an old rat shack cd player and early eighties kenwood amps(makes what they are doing even more impressive). I will build 4 x 50 watt amps so that my freind can afford an active version, probably Marchandelec.com kits for the convenience and value.
What are those rails you have mounted the neo's on? Those things are going to be a be-atch to flush mount, I will have to make a template for the router. Also, are you getting any hot spots off the window? Using any absorption behind the neo line, or is closing the drapes enough? Even with some distance behind them, I have to use absorption on the cellar wall so images are not pulled to highly reflective areas.
Have you put the neo's on the outside to better time align the cones with the ribbons? I probably won't be able to reply until tomorrow, as the connection at the university where I work is so much faster than home. Once again, excellent job.
regards, Jason
Unbaffled
Old 9th October 2002, 09:42 PM   #29
The rails you see on the photo are aluminum "L" shape. I'm using heavy drapes to block reflections so I don't have any hot spots from the window. I tried both sides but found that putting the Neo8 line outside of the enclosure improved imaging and soundstage. I'm in fact really impressed by how wide they image. Wider than 180 degree on some recording. My biggest problem right now is a hole in the 100Hz region. Any suggestions?
Old 11th October 2002, 11:41 AM   #30
Don't mind notch filters, but filling holes is another matter. What are you crossed to under 50hz? These drivers are 3db down at what-70-80hz? Raising the cross might be the only solution...
I am pretty satisfied with the treble extension for the type of recordings that I enjoy. My freind, however, has a rather large collection of 70's and 80's rock on cd! The lack of treble extension might help
After looking at your line, I think I will try putting the neos slighltly to the outside of the center of the 2 peerless to improve time alignment between the cone and planar.
BTW-Listened to Clapton unplugged last night with just a 6db cross at 800hz-the guitar sounded so right. I miss those box resonances
Regards, Jason
Unbaffled
Bohlender&Graebener Neo 8 MagnetostatHide this!Advertise here!
Bohlender Graebener Ribbons AuroraB Multi-Way 32 12th July 2012 04:30 AM
Bohlender Graebener Neo3 where to buy el_mariachi Multi-Way 18 16th July 2006 05:53 AM
Bohlender & Graebener transducers setmenu Multi-Way 13 25th August 2002 05:07 PM
Toam Bohlender and David Graebener gvinson Multi-Way 5 25th January 2002 07:57 PM
