metal boxes for you
hi,
MDF is not so bad if is thick 3cm or more, but can be inside glue/plate with ceramics tiles,
all around, find the right sizes for your boxes and just make the cutting around the unit opening,
this is not a new idea it was in use for some UK manufacturers.
But if you want to see some thing out of the blue look here: www.yg-acoustics.com
Regards Williams
hi,
Regards Williams
Back in the late 80s I owned a body shop and needed speakers to take 4 wheelin' Used a beer keg with 2 12" subs one in each end and later and alum. box w/2 12" & 2 10" both were lined with fiber glass they sounded ok but I was young then and loud ment good. they did hold up to a lot of abuse
