After reading this this thread, I picked up a pair of tang band W3-594S full range speakers for my first ever diy. Specifications: Power Handling: 15 watts RMS/30 watts max * Voice coil diameter: 3/4" * Nominal Impedance: 8 ohms * Re: 6.6 ohms * Frequency range: 100-20,000 Hz * Fs: 100 Hz * SPL: 87 dB 1W/1m * Vas: .06 cu.ft. * Qms: 6.59 * Qes: .71 * Qts: .64 * Xmax .4 mm * Dimensions: A: 3-3/16", B: 3-1/16", C: 2-1/4", D: 2-5/8"
Subsequently I decided to make a vented wood box instead of small cube (I read Martin King's articles on Transmission Lines, but I think it is going to take some more time before I understand them and start using them for designing TLs). Since I do not have a table saw, I am planning to use standard 2X4 and 2X6 wood planks available in HomeDepot. With internal width of 3.5" and depth of 2.5" (as show in the picture), the required height is 55" to acheive 8L volume for -3dB at 55Hz (as calculated by WinISD. My question: Is such an abnormally large H in comparison to W and D going to create problems with the box response? |
#2 |
What are you expecting out of this dinky speaker when used full range? One decent bass note at a reasonable volume and the cone is going to fly right out of the cabinet, if it hasn't gone up in smoke first.
You need a more ambitious project unless you are making a table radio. |
#3 | |
Well I guess I will stick to small cube then, but this is where I got the idea from.
#4 |
Well, the thread you reference is for a different driver, a 4". I used a 3.5L vented box for a w3-881s, which is not the same driver but similar. You may like to consider finding some 1/4" material, such as "hobby boards" or oak finishing panels.
Good luck! JohnR |
#5 |
frugal-phile(tm)
Bill sure is cranky to-nite.
What he is saying (i interperet) in his sarcastic tone is that these are limited in excursion. A reflex box will unload the speaker below the box tuning and you could be putting a lot more stress on the driver. I'd go with a 6-8 litre sealed box and plan on adding a subwoofer if you need more bottom. They will never play really loud, but should have quite a nice seemless midrange. The long length will resonate. If you add a port you will be making a mass-loaded straight pipe. With their highish Q you could also use them in an open-baffle if you could limit the amount of LF they were exposed to. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#6 | |||
So, it looks like I have only 2 options: sealed box or open baffle. Quote:
#7 |
frugal-phile(tm)
| Design Questions | amirmk | Tubes / Valves | 5 | 26th September 2005 02:17 PM |
| Aussie specific newb questions | fb | Multi-Way | 9 | 22nd August 2005 01:32 AM |
| PCB Design Questions | Sherman | Chip Amps | 6 | 2nd June 2004 09:23 PM |
| Some Design Questions | coolkhoa | Multi-Way | 13 | 17th March 2004 09:19 PM |
| X-over design questions | Milzie | Multi-Way | 7 | 6th November 2002 12:33 PM |
| Page generated in 0.14387 seconds (76.24% PHP - 23.76% MySQL) with 11 queries |
