I built my first speakers yesterday and I'm shocked they sound as open and full bodied as they do considering my lack of knowledge with diy speakers. 24x48x.75" mdf with Eminence 2002 horn tweeter with 1 uf cap, Beta 12 lt wide band, and Delta 15lt ran straight off the Beta.( I need inductor here). I have been using Maggies and wanted to maintain the 3d soundstage they have while improving sensitivity, dynamics and bass. I think the open baffle can definitely do it with a little fine tuning. If there is anyone interested who lives around Detroit MI with some equipment for measuring response I would love to bring them over to see where the weak spots are. This site has been extremely helpful so far, thanks. Matt
I will attach photos as soon as I find out how to shrink them to size. |
#2 |
#3 |
photo rear
#4 |
Nice Job there ! I use Eminece spkrs for my guitar cabinet (4x10 legend 102) and bass cabinet (2x12 beta) (2x15 kappa pro). Never had in mind to use them in home audio. How's the 'vocal' ? What power amp do you use ? Thanks, Wil |
#5 |
Thanks, I have some work to do in getting drivers integrated properly with high low passes, but want to listen for a while to see what happens. So far the vocals are very good, "well rounded", if I run the tweeter in a little lower I should get a little more air I think. I must get a low pass on the 15 though to clean up the bass.
I am using a tube pre and ss amp both from Balanced Audio Tech. vk3i and vk 200. Very good stuff I feel, but I want to build a pair of tube monos, maybe Bottleheads. Matt |
#6 |
here's the finished baffles. Still need xo work, still smiling.
#7 |
close up of figured maple veneer, definitely not a pro woodworker but it does capture the look I wanted pretty well.
#8 |
Nice looking baffles you got there. Like the looks with the stripes.
Is your rack DIY or which manufacturer is that? In case you wanna cut the 15" real low you could think about a cheap active solution if you donīt mind (and have) another amplifier. (some simple solid state amp; guess the 15" donīt mind a bit more power in the baffles as well) A Behringer CX-2310 works pretty well for me. Might be cheaper than trying a few of those big and expensive coils? greets
jens |
#9 |
Thanks, The rack is simply the Lovan Classics stackable frames with shelves I had cut locally made of marble and granite. I have been thinking of doing a butcherblock rack like the Mapleshade Samson.
Your advice for going active is exactly what I've been thinking about, just getting sub amps so I can adjust gain and xo freq. |
#10 | |
only phase canīt be adjusted. If you have a separate preamp (and another amp) passive line level crossovers might be an option too. http://www.t-linespeakers.org/tech/f...ssiveHLxo.html greets
jens |
| 3 way open baffle with Eminence and Skytronic | SimontY | Multi-Way | 452 | 16th September 2011 09:25 PM |
| Eminence or P.Audio ? Open Baffle or Sealed | Predator864 | Multi-Way | 0 | 23rd January 2009 11:51 AM |
| Newbie open baffle questions | wixy | Multi-Way | 1 | 21st December 2007 10:25 PM |
| Fostex FE207E with Eminence Alpha 15 open baffle | sharpi31 | Multi-Way | 15 | 21st September 2007 03:20 AM |
| Eminence Kappalite 3015 as open baffle bass? | EC8010 | Multi-Way | 4 | 29th June 2007 08:05 AM |
| Page generated in 0.11574 seconds (81.81% PHP - 18.19% MySQL) with 11 queries |
